Mass Air Flow Sensor Data
Results 1 to 3 of 3
    Feb 2005
    Indiana
    Angry Mass Air Flow Sensor Data
    I want to build an Industrial device that needs to measure mass air flow in the same range as typical Automotive MAF Sensors. I have searched for actual data(i.e. Actual Mass Air Flow verses Voltage Out) for any models with no luck. Any thoughts? Thanks, John
    JRudd
    Mar 2006
    Pennsylvania, USA.
    Circuit Cellar Ink # 138, around 2002, I think, had a great article on building an engine control unit for fuel injected engines. It should at least get you started.
    Jerry
    If your oscilloscope costs more than your car...
    Dec 2005
    So Cal and loving it
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 20:42
  2. Flow Code
    By wbjunkie in forum General
    Last Post: - 16th December 2008, 22:23
  3. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 04:05
  4. flow control
    By pierre2030 in forum mel PIC BASIC Pro
    Last Post: - 15th February 2006, 04:53
  5. Stack Under flow
    By Wayne in forum mel PIC BASIC Pro
    Last Post: - 14th September 2005, 13:22
