Pickit 2 saving varables?
Results 1 to 6 of 6
    jessey's Avatar
    jessey Guest
    Default Pickit 2 saving varables?
    Hello Everyone,
    I can't seem to get my 18f452 to save variables to the eeprom, I've posted this here because I'm thinking this has something to do with the pickit 2 set-up and not the picbasic pro code. I've used these same routines before to save to the eeprom and it has worked good in the past. I have the "Program Memory" and the "EEprom Data" boxes selected for hex only but have tried other settings as well with no success. Can anyone here in the know suggest what settings need to be looked at in the pickit 2 in order to get this code to work properly? Any help will be greatly appreciated.
    jessey
    '* Name     : Car_Thermostat.bas                                               *
    '* Author   : Jessey Montgomery                                                *
    '* Includes : STRINGS.PBP By Darrel Taylor                                     *
    '* Notice   : Copyright (c) 2004                                               *
    '*          : All Rights Reserved                                              *
    '* Date     : 22/10/2005                                                       *
    '* Version  : Using PicBasic Pro Ver 2.50, MPASM Ver 5.20, Using MicroCode     *
    '*          : Studio 3.0.0.5, PICkit 2 programmer - Application Version        *
    '*          : 2.50.02 - Device File Version 1.5100 - OS Firmware Version       *
    '*          : 2.30.01. Using a PIC18f452-20/P                                  *
    '                                |   18F452   |
    '               MCLR/Vpp ------> |1         40| <-----> RB7/PGD
    '                RA0/AN0 <-----> |2         39| <-----> RB6/PGC
    '                RA1/AN1 <-----> |3         38| <-----> RB5/PGM
    '          RA2/AN2/Vref- <-----> |4         37| <-----> RB4
    '          RA3/AN3/Vref+ <-----> |5         36| <-----> RB3/CCP2*
    '              RA4/TOCK1 <-----> |6         35| <-----> RB2/INT2
    '       RA5/AN5/SS/LVDIN <-----> |7         34| <-----> RB1/INT1
    '             RE0/RD/AN5 <-----> |8         33| <-----> RB0/INT0
    '             RE1/WR/AN6 <-----> |9         32| <-----  Vdd
    '             RE2/CS/AN7 <-----> |10        31| <-----  Vss
    '                    Vdd  -----> |11        30| <-----> RD7/PSP7
    '                    VSS  -----> |12        29| <-----> RD6/PSP6
    '              OSC1/CLK1  -----> |13        28| <-----> RD5/PSP5
    '          OSC2/CLKO/RA6 <------ |14        27| <-----> RD4/PSP4
    '        RC0/T1OSO/TICK1 <-----> |15        26| <-----> RC7/RX/DT
    '        RC1/T1OSI/CCP2* <-----> |16        25| <-----> RC6/TX/CK
    '               RC2/CPP1 <-----> |17        24| <-----> RC5/SDO
    '            RC3/SCK/SCL <-----> |18        23| <-----> RC4/SD1/SDA
    '               RD0/PSP0 <-----> |19        22| <-----> RD3/PSP3
    '               RD1/PSP1 <-----> |20        21| <-----> RD2/PSP2
    '                               ADC pins and ports
    '                              AN0  (pin 2)   PORTA.0
    '                              AN1  (pin 3)   PORTA.1
    '                              AN2  (pin 4)   PORTA.2
    '                              AN3  (pin 5)   PORTA.3
    '                              AN4  (pin 7)   PORTA.4
    '                              AN5  (pin 8)   PORTE.0
    '                              AN6  (pin 9)   PORTE.1
    '                              AN7  (pin 10)  PORTE.2
    '-- Clear All The Variables And Each Port Before Setting The TRIS Registers ---'
    Clear    'Set all ram registers to zero
    PORTA = 0
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    '--------------------------- VSS VDD MCLR Etc. Pins ---------------------------'
    'MCLR        (Pin 1)
    'VDD         (Pin 11)
    'VSS         (Pin 12)
    'OSC/CLKIN   (Pin 13)
    'OSC2/CLKOUT (Pin 14)
    'VSS         (Pin 31)
    'Vdd         (Pin 32)
    '((OPTION_REG=127 ' ENABLE WEAK PULL UP RESISTORS ON PORTB))
    'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
    'XXXXXXXXXXXXXXXXXXXXXXXXXX Set The TRIS In/Out Pins XXXXXXXXXXXXXXXXXXXXXXXXXX'
    'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX BELOW XXX'
    '-------------------- PORTA PINS --------------------'
    TRISA.0 = 1  '(pin 2) ..........Adjust_Hi_Temp_Push_Button VAR PORTA.0   ' pin 2
    TRISA.1 = 1  '(pin 3) ..........Adjust_Low_Temp_Push_Button VAR PORTA.1  ' pin 3
    TRISA.2 = 1  '(pin 4) ................Decrease_Push_Button VAR PORTA.2   ' pin 4
    TRISA.3 = 1  '(pin 5) .................Increase_Push_Button VAR PORTA.3  ' pin 5
    TRISA.4 = 1  '(pin 6) NOT USED
    TRISA.5 = 1  '(pin 7) NOT USED
    '-------------------- PORTB PINS --------------------'
    TRISB.0 = 1  '(pin 33) NOT USED VAR PORTB.0 'pin 33
    TRISB.1 = 1  '(pin 34) NOT USED VAR PORTB.1 'pin 34
    TRISB.2 = 1  '(pin 35) NOT USED VAR PORTB.2 'pin 35
    TRISB.3 = 1  '(pin 36) NOT USED VAR PORTB.3 'pin 36
    TRISB.4 = 1  '(pin 37) NOT USED VAR PORTB.4 'pin 37
    TRISB.5 = 1  '(pin 38) NOT USED VAR PORTB.5 'pin 38
    TRISB.6 = 1  '(pin 39) NOT USED VAR PORTB.6 'pin 39
    TRISB.7 = 1  '(pin 40) NOT USED VAR PORTB.7 'pin 40
    '-------------------- PORTC PINS --------------------'
    TRISC.0 = 1  '(pin 15) ................................DS1820 Temperature Sensor
    TRISC.1 = 1  '(pin 16) NOT USED VAR PORTC.1 'pin 16
    TRISC.2 = 1  '(pin 17) NOT USED VAR PORTC.2 'pin 17
    TRISC.3 = 1  '(pin 18) NOT USED VAR PORTC.3 'pin 18
    TRISC.4 = 1  '(pin 23) NOT USED VAR PORTC.4 'pin 23
    TRISC.5 = 1  '(pin 24) NOT USED VAR PORTC.5 'pin 24
    TRISC.6 = 1  '(pin 25) NOT USED VAR PORTC.6 'pin 25
    TRISC.7 = 1  '(pin 26) NOT USED VAR PORTC.7 'pin 26
    '-------------------- PORTD PINS --------------------'
    TRISD.0 = 1 '(pin 19) NOT USED VAR PORTD.0 'pin 19
    TRISD.1 = 0 '(pin 20) .............................Buzzer VAR PORTD.1  '(pin 15)
    TRISD.2 = 0 '(pin 21) ...............................The_Fan VAR PORTD.2 'pin 21
    TRISD.3 = 1 '(pin 22) NOT USED VAR PORTD.3 'pin 22
    TRISD.4 = 0 '(pin 27) ...........................Lcd out for Data bit 4
    TRISD.5 = 0 '(pin 28) ...........................Lcd out for Data bit 5
    TRISD.6 = 0 '(pin 29) ...........................Lcd out for Data bit 6
    TRISD.7 = 0 '(pin 30) ...........................Lcd out for Data bit 7
    '-------------------- PORTE PINS --------------------'
    TRISE.0 = 0 '(pin 8)  ...........................LCD FOR Register/Select
    TRISE.1 = 0 '(pin 9)  ...........................LCD Enable
    TRISE.2 = 1 '(pin 10) NOT USED PORTE.2
    '--------------------- Lcd Set Up For Parallel 4 Bit Mode --------------------'
    '----------------------- Using Melanie's Cool Blue Lcd -----------------------'
    '  LCD       Wire
    'Pin No.   Color         Symbol    Function          Connections To 18F452
    '  A     Red / Black     A        Back Light +       To +5V through 1.5K res
    '  K     Black /White    K        Back Light -       To -5V
    '  1     Black           Vss      Negative 5V        To -5V
    '  2     Red             Vdd      Positive 5V        To +5V
    '  3     White / Black   Vo       LCD cont adj.      To -5V through 1.5K res
    '  4     Orange/Black    RS       Register select    Connect to pin 8 RE0
    '  5     Red / White     R/W      Read / write       Connect to -5V
    '  6     Blue / White    E        Enable             Connect to pin 9 RE1
    '  7    (not used)       DB0      Data bit 0
    '  8    (not used)       DB1      Data bit 1
    '  9    (not used)       DB2      Data bit 2
    '  10   (not used)       DB3      Data bit 3
    '  11    Blue            DB4      Data bit 4         Connect to pin 27 RD4
    '  12    White           DB5      Data bit 5         Connect to pin 28 RD5
    '  13    Green           DB6      Data bit 6         Connect to pin 29 RD6
    '  14    Orange          DB7      Data bit 7         Connect to pin 30 RD7
    ;@ __CONFIG _CONFIG1H, _OSCS_ON_1H & _XT_OSC_1H ' use this one for 4 mhz and
                                                    ' also declare the osc as 4mhz
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H ; use this one for 16 mhz
    @ __CONFIG _CONFIG2L, _BOR_OFF_2L & _BORV_20_2L & _PWRT_ON_2L
    @ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    @ __CONFIG _CONFIG3H, _CCP2MX_OFF_3H
    @ __CONFIG _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    @ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_ON_6H
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
     DEFINE OSC 16     ' using HSPLL X 4 gives us OSC 16
    @ errorlevel -306 ; turn off the Crossing page boundary warnings
     Define LCD_DREG   PORTD
     Define LCD_DBIT   4
     Define LCD_RSREG  PORTE
     Define LCD_RSBIT  0
     Define LCD_EREG   PORTE
     Define LCD_EBIT   1
    '--------------------- Configure Pins ----------------------'
    ADCON1 = 7  ' Set to Digital
    'Pushbuttons Variables '
    'Port pins Variables '
     Buzzer VAR PORTD.1         ' pin 20
     The_Fan VAR PORTD.2        ' pin 21
     ' Allocate variables '
     a var byte                 ' Enables if..then statements to execute without
     a = 0                      ' using GOTO's, a always equals 0
     b Var Word
     c Var byte                 ' used to select a print to show to the Lcd
     D Var Byte                 ' used to speed up var changes using push buttons
     Var_Pause Var Byte         ' used to extend the time in for next loops
    Variable_Pause Var Byte     ' used to speed up var changes using push buttons
    Pause_Counter Var Word      ' used to speed up var changes using push buttons
    'used for temperature'
    temp VAR	WORD           ' Temperature storage
    count_remain VAR BYTE   ' Count remaining
    count_per_c VAR BYTE    ' Count per degree C
    Sign  VAR  BIT          ' bit determines id - sign is needed
    DQ VAR PORTC.0          ' One-wire data pin (pin 15)
    EEPROMData91 var byte              'Define EEPROM Data
    Hi_Temp_Setpoint VAR EEPROMData91  'alias the Hi_Temp_Setpoint
    Read 91, EEPROMData91              'Read into Hi_Temp_Setpoint
    'To save the var write'
    'EEPROMData91 = Hi_Temp_Setpoint   'save our Hi_Temp_Setpoint adjustment
    'Write 91, EEPROMData91
    EEPROMData92 var byte                 'Define EEPROM Data
    Low_Temp_Setpoint VAR EEPROMData92    'alias the Low_Temp_Setpoint
    Read 92, EEPROMData92                 'Read into Low_Temp_Setpoint
    'EEPROMData92 = Low_Temp_Setpoint     'save our Low_Temp_Setpoint adjustment
    'Write 92, EEPROMData92
     Is_On CON 1
     Is_Off CON 0
     Is_Pressed CON 0
     Is_Not_Pressed CON 1
     LCDOUT  254,64,14,10,14,0,0,0,0,0 ' Custom Char #0 - degree sign
     Pause 1000' wait for Lcd to initialize
        LCDOut $fe, 1, "Taurus Controller"
      LCDOut $fe, $c0, "By JJ Montgomery"
      PAUSE 2000
       GOSUB Check_Temperature
       If a = 0 Then mainloop' Skip subroutines
    Sound_Buzzer:
                PWM  Buzzer,250,15
    Save_The_Hi_Temp_SetPoint:
           EEPROMData91 = Hi_Temp_Setpoint ' save our Hi_Temp_Setpoint adjustment
    Save_The_Low_Temp_SetPoint:
           EEPROMData92 = Low_Temp_Setpoint'save our Low_Temp_Setpoint adjustment
    Print_Release_Button:
       LCDOut $fe, 1, " Release Button "
     LCDOut $fe, $c0, "   To Return    "
    Show_Print_To_Lcd:
      If c = 0 then
           LCDOut $fe, 1, "Adj The Hi Temp "
      Else ' if c = 1
           LCDOut $fe, 1, "Adj The Low Temp"
      Endif
         LCDOut $fe, $c0, "Release Button  "
    'This speeds up the var change when either of these two push buttons are held down
    _Pause:
         IF Increase_Push_Button = Is_Not_Pressed THEN
          If D = 0 then
            Pause_Counter = 0
          Endif
         Endif
         IF Decrease_Push_Button = Is_Not_Pressed THEN
          If D = 1 then
            Pause_Counter = 0
          Endif
         Endif
         If Pause_Counter >= 63000 Then Pause_Counter = 50
         Pause_Counter = Pause_Counter + 1
         If Pause_Counter <= 9 Then Variable_Pause = 100
         If Pause_Counter = 10 Then Variable_Pause = 75
         If Pause_Counter = 20 Then Variable_Pause = 50
         If Pause_Counter = 30 Then Variable_Pause = 25
         If Pause_Counter >= 40 Then Variable_Pause = 5
         Pause Variable_Pause
    Adjust_Hi_Temp_Set_Point:
      GOSUB Sound_Buzzer : c = 0 : Variable_Pause = 100
      WHILE Adjust_Hi_Temp_Push_Button = Is_Pressed
         Gosub Show_Print_To_Lcd
         Pause 100
      WEND
      Pause 200 ' Button Debounce
       Var_Pause = 100 ' using 100, this loop times out in 11 seconds & returns
      Loop_1:
         Var_Pause = Var_Pause - 1
        'Increase the Hi_Temp_Setpoint'
         IF Increase_Push_Button = Is_Pressed THEN
           GOSUB Sound_Buzzer' button press indicator
           Var_Pause = 100 ' allow more time in this loop when button is pressed
           Hi_Temp_Setpoint = Hi_Temp_Setpoint + 1
           Gosub Save_The_Hi_Temp_SetPoint
           D = 0
        'Decrease the Hi_Temp_Setpoint'
         IF Decrease_Push_Button = Is_Pressed THEN
           Hi_Temp_Setpoint = Hi_Temp_Setpoint - 1
           D = 1
             'Show the Hi_Temp_Setpoint increment & decrement'
               LCDOut $fe, 1, DEC temp / 100,0," Hi Turn On "
             LCDOut $fe, $c0, " Fan On @ ", dec Hi_Temp_Setpoint,0,"F "
         If Adjust_Hi_Temp_Push_Button = Is_Pressed Then
           GOSUB Sound_Buzzer
           Var_Pause = 100
              Gosub Print_Release_Button
               Pause 100
           WEND
         Endif
         Gosub _Pause ' pause changes (speeds up) when button is held down
        If Var_Pause <= 1 Then
          GOSUB Sound_Buzzer
        Endif
      If a = 0 Then Loop_1
    RETURN ' auto return when the Var_Pause = 1
    Adjust_Low_Temp_Set_Point:
       GOSUB Sound_Buzzer : c = 1 : Variable_Pause = 100
       WHILE Adjust_Low_Temp_Push_Button = Is_Pressed
         Pause 100
       WEND
      Loop_2:
        'Increase the Low_Temp_Setpoint'
           Low_Temp_Setpoint = Low_Temp_Setpoint + 1
           Gosub Save_The_Low_Temp_SetPoint
           D = 0
        'Decrease the Low_Temp_Setpoint'
           Low_Temp_Setpoint = Low_Temp_Setpoint - 1
           D = 1
            'Show the Low_Temp_Setpoint increment & decrement'
               LCDOut $fe, 1, DEC temp / 100,0," Lo Turn Off"
             LCDOut $fe, $c0, "Stop Fan @ ", dec Low_Temp_Setpoint,0,"F "
         If Adjust_Low_Temp_Push_Button = Is_Pressed Then
           GOSUB Sound_Buzzer
              Pause 100
           WEND
         Endif
          GOSUB Sound_Buzzer
        Endif
      If a = 0 Then Loop_2
    Check_Temperature:
      OWOut DQ, 1, [$CC, $44]    ' Start Temp conversion
     waitloop:
       If count_remain = 0 Then b = b + 1     '
       If b >= 25000 then                     '
        Loop_4:                               '
            LCDOut $fe, 1, "Temp Sensor Has " '
          LCDOut $fe, $c0, "Malfunctioned!2!" ' this detects a sensor malfunction
          PWM  Buzzer,255,100                 '
          The_Fan = Is_On                     '
          Pause 100                           '
        If a = 0 then Loop_4                  '
       Endif                                  '
      OWIn DQ, 4, [count_remain]	' Check for still busy converting
    	IF count_remain = 0 THEN waitloop
    	OWOut DQ, 1, [$CC, $BE]		  ' Read the Temp
      OWIn DQ, 0, [temp.LOWBYTE, temp.HIGHBYTE, _
                            Skip 4, count_remain, count_per_c]
        ' Calculate temp in degrees Celsius to 2 decimal places
         Sign = temp.15
         temp = ((ABS(temp) >> 1) * 100)
         if Sign then temp = -temp
         temp = temp - 25 _
                         + (((count_per_c - count_remain) * 100) / count_per_c)
        ' Convert Celsius to Fahrenheit before returning
         Sign = temp.15
         temp = (ABS(temp) */ 461)
         temp = temp + 3200
     mainloop:
      b = 0 ' reset var to prevent the alarm from going off
     If Temp / 100 <= 31 Then                '
       Loop_3:                               '
         LCDOut $fe, $c0, "Malfunctioned!1!" ' this detects a sensor malfunction
         The_Fan = Is_On                     '
         Pause 100                           '
       If a = 0 then Loop_3                  '
     Else                                    '
    '  LCDOut $fe, 1,"Engine H2o Temp "
       LCDOut $fe, 1,"Monitor Collant "
       LCDOut $fe, $c0
       LCDOut "  Temp = "
       if temp.15 = 1 then LCDOut "-"
       temp = ABS(temp)
       LCDOut DEC temp / 100,0
       LCDOut "F "
     Endif                                   '
     If Temp / 100 >= Hi_Temp_Setpoint then The_Fan = Is_On
     If Temp / 100 <= Low_Temp_Setpoint then The_Fan = Is_Off
     If Adjust_Hi_Temp_Push_Button = Is_Pressed Then Gosub Adjust_Hi_Temp_Set_Point
     If Adjust_Low_Temp_Push_Button = Is_Pressed Then Gosub Adjust_Low_Temp_Set_Point
     Pause 100
    Hi Jessey,
    I think you have the DATA memory protected in your configs.
    jessey's Avatar
    jessey Guest
    Smile Thanks Darrel
    Hi Jessey,
    Hi Darrel, Much appreciated, seems I'm always in your debt...
    jessey's Avatar
    jessey Guest
    Default better search engine
    Hey Darrel,
    Thanks for saving me on the eeprom configuration booboo, it's working great now. What happened to your search engine that was in the off topic area? It works a lot better than the search engine here by leaps and bounds. Where is it hiding?
    jessey
    The search tool is in the FAQ section. First post.
    Kind of hard to find there but a little looking you should see it
    jessey's Avatar
    jessey Guest
    Thanks, I'll have a look...
    jessey
