Well, now that I've switched from PBP2..6 to PBP3 I seem to be having trouble with DT_Interrupts in some "previously working" code.
I've read the manual about migrating from PBP2.6 to 3.0, and have successfully applied it to other programs, but can't seem to get it going on this one.
The chip is a 16F726. It uses DT_interrupts in a touch sensor routine.
The code worked when compiled with PBP2.6 but creates some "ASM Errors" with PBP3
Here's the errors I get:
Here's my ASM code. First, some config stuff.
Used to be:
@ __config _CONFIG1, _DEBUG_OFF & _PLL_EN & _BORV_2_5 & _BOR_ON & _CP_OFF & _MCLRE_OFF & _PWRT_EN & _WDT_OFF & _INTOSCIO
@ __config _CONFIG2, _VCAP_RA0
Now looks like:
#endCONFIG
Then I set up the interrupt. Here's my OLD code for PBP2.6:
'-----Set up Interrrupts
INT_Handler TMR1GATE_INT, _CheckCount, PBP, yes
@ INT_ENABLE TMR1GATE_INT ; enable Timer 2 interrupts
And the NEW code for PBP3:
INT_ENABLE TMR1GATE_INT ; enable Timer 1 interrupts
At the end of my interrupt handler routine I had this:
Which has been changed to this:
INT_RETURN
That'all the ASM there is.
I clearly haven't done it right... could someone point me in the right direction?
Thanks!
