compilation error
Results 1 to 12 of 12
    Jan 2012
    Default compilation error
    Hallo everyone,
    I just copied this code from Rentron electronics and tried to compile it to get a hex code to programme the pic16f628, but unfortunately I get an error and I can't seem to get the hex code.
    I use Nigel Goodwin's WinPicProg, and whenever I try to set the fuses there I also get a verification error. Even when I disable the auto verify I can't get the hex code.
    Here is the first part of the code causing the error:
    @ DEVICE MCLR_OFF, INTRC_OSC, WDT_OFF, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF
    Illegal Opcode (MCLR_OFF)
    the complete code is here:
    http://www.rentron.com/PicBasic/IR_Chips.htm
    I appreciate your help!
    Many thanks in advance.
    Default Re: compilation error
    Why are you using that?
    Use MicroCode Studio that comes with PicBasicPro to edit the code and to invoke PicBasic to compile it.
    Jan 2012
    Thanks for the instant reply,
    But this is how I had learned to do the job for some time in the past before I started some C ...etc.
    please see attachment
    For the 628A...
    @ DEVICE MCLRE_OFF, INTRC_OSC, WDT_OFF, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF
    And the config type you are using is for PM. Is that set correctly in MCS?
    Check the code here:
    http://www.picbasic.co.uk/forum/showthread.php?t=15960
    You are missing the PIC model after DEVICE.
    Jan 2012
    For the 628A...
    thanks for the reply,
    I tried your suggestion but I keep getting an error
    Jan 2012
    Thanks for the reply,
    And by the way interesting tutorial for me for further and later needs.
    But as for now I need this job urgently done for this IR project and I can't seem to get anywhere except with illegal opcode and found label after column 1 (DEVICE).
    You still do not have
    MCLRE
    Jan 2012
    MCLRE
    I did! Here it is once again!
    See if this works. I was not paying attention, you are using PBP 3 ?
    __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _LVP_OFF & _CP_OFF & _MCLRE_OFF
    This should work;
     __CONFIG _MCLRE_OFF & _INTRC_OSC_NOCLKOUT & _WDT_OFF & _LVP_OFF & _BODEN_OFF & _PWRTE_ON
    And disable case sensitivity in MPASM or make porta PORTA in the assembler part.
    -Bruce
    tech at rentron.com
    Jan 2012
    Lots of thanks to all contributions!
    Now I've got it.
    Special thanks to you Bruce, you just saved me a lot of effort.
    I was about to call Rentron and report this as I tried another code and had the same problem.
    Best regards to all.
