Compilation Error
Results 1 to 5 of 5
    Sep 2015
    Post Compilation Error
    fatal: out of memory (pbpw.exe)
    I has changing the directory where the source code to one closer to c: (root), hut still can't work
    Default Re: Compilation Error
    Quote Originally Posted by Winchester View Post
    Attachment 8063
    Wow Winchester, I have no real answer for you but I have an observation, look at the error message where it says line 16 col 122 . . .
    there is something in that spot, maybe you should delete?
    That's not part of the error message, it just tells you where the cursor is.
    At first I thought it was the GOTO, outside of the END statement (which probably isn't what you actually want) that caused the error but prior to posting this I tried it my end it compiles just fine.
    Yup, Heinrik You're right on both counts, and it compiled for me too, maybe he needs to reinstall or give the program better permissions, or use compatible mode.
    Dec 2010
    I see this every once in awhile, but not since I upgraded to more memory. Shutting down and rebooting always fixes it. I suspect the program has a minor memory leak.
  1. compilation error
    By Protech in forum mel PIC BASIC Pro
    Last Post: - 8th January 2012, 20:14
  2. Compilation errors
    By aratti in forum mel PIC BASIC Pro
    Last Post: - 8th September 2010, 15:12
  3. Compilation errors
    By mikebike in forum mel PIC BASIC Pro
    Last Post: - 6th September 2010, 09:29
  4. Warning (and other Compilation Error) Messages
    Last Post: - 9th September 2009, 01:29
  5. Compilation error Block overflow for ENDASM
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2006, 01:20
