18F45K22 Pull Up on PortE
Results 1 to 3 of 3
    Default 18F45K22 Pull Up on PortE
    It seems trivial but unortunately I cannot enable the Pull Ups on the Port E <0:1> of the 45K22.
    Here is my setup:
        CONFIG  FOSC = INTIO67        ; Internal oscillator block
        CONFIG  PLLCFG = ON           ; PLL Control
        CONFIG  PRICLKEN = OFF        ; Primary clock can be disabled by software
        CONFIG  PWRTEN = OFF          ; Power up timer disabled
        CONFIG  BOREN = SBORDIS       ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  BORV = 190            ; VBOR set to 1.90 V nominal
        CONFIG  WDTEN = OFF           ; WDT is always enabled. SWDTEN bit has no effect
        CONFIG  WDTPS = 32768         ; 1:32768
        CONFIG  CCP2MX = PORTC1       ; CCP2 input/output is multiplexed with RC1
        CONFIG  PBADEN = OFF          ; PORTB<5:0> pins are configured as digital I/O on Reset
        CONFIG  CCP3MX = PORTB5       ; P3A/CCP3 input/output is multiplexed with RB5
        CONFIG  HFOFST = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  T3CMX = PORTC0        ; T3CKI is on RC0
        CONFIG  P2BMX = PORTD2        ; P2B is on RD2
        CONFIG  MCLRE = EXTMCLR       ; MCLR pin disabled, RE3 input pin enabled
        CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
        CONFIG  DEBUG = OFF           ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800-001FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (002000-003FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (004000-005FFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (006000-007FFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-001FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (002000-003FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (004000-005FFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (006000-007FFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    DEFINE OSC 64
    ' Setup PLL for 64 MHZ
    OSCCON = %01110000 ; 16 mhz (NOTE: SCS=0 so PLL works)
    OSCCON2= %00000100
    OSCTUNE= %01000000 ; PLL enable Mhz * 4
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    ' Set LCD Data port
    DEFINE LCD_DREG PORTD  ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0      ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTC ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 2     ' Set LCD Enable port
    DEFINE LCD_EREG PORTC  ' Set LCD Enable bit
    DEFINE LCD_EBIT 3      ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4      ' Set number of lines on LCD
    DEFINE LCD_LINES 4     ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500  ' Set data delay time in us
    DEFINE LCD_DATAUS 50   ' Set receive register to receiver enabled
    DEFINE HSER_RCSTA 90h ' Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA 20h ' Set baud rate
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG1 103
    DEFINE HSER_CLROERR 1  ' Auto clear over-run errors
    'DEFINE HSER_TXSTA 24h '9600 baud rate, BRGH=1
    'DEFINE HSER_BAUD 115200
    'DEFINE HSER_SPBRG1 34
    BAUDCON1 = %00000000   ' bit 4 0:Needs UART, 1:No UART chip
    INTCON2.7=0
    WPUB.5=1
    CM1CON0.7=0
    CM2CON0.7=0
    'PWM 1 and PWM 2 module settings
    '''trisb.5=1:trisc.1=1     'disable output
    '''ccptmrs0=0
    '''ccptmrs1=0
    '''PR2=255
    ''''CCP1CON=$0C
    '''CCP2CON=$0C
    '''CCP3CON=$0C
    ''''ccp1con.5=0:ccp1con.4=0:ccpr1l=0
    '''ccp2con.5=1:ccp2con.4=1:ccpr2l=255
    '''ccp3con.5=1:ccp3con.4=1:ccpr3l=255
    ''''clear
    '''pir1.1=0
    '''t2con=%0000101
    '''while !pir1.1:wend
    '''trisb.5=0:trisc.1=0     'enable output
    'Initializing Port Registers
      PORTA = 0:PORTB = 0:PORTC = 0:PORTD = 0:PORTE = 0
      TRISA = 0:TRISB = 0:TRISC = 128:TRISD = 0:TRISE = %10000011
    ' Main Program
    start:
    WHILE 1
    IF PORTE.1 then
        LCDOUT $FE,$80,"Card present"
        LCDOUT $FE,$80,"Card absent "
    WEND
    It does not enable the pull ups on port E no matter what. Any help appreciated.
    Oct 2011
    Pennsylvania
    Default Re: 18F45K22 Pull Up on PortE
    Hi Ioannis,
    Looking at the datasheet DS41412F page 10, it seems to me that on the E-port only RE3 has the Pull-up function built in.
    Thanks Steve.
    On page 156 it shows that the TRISE register includes both port direction AND pull up setting without mention that the pull up is only on portE.3 as you clearly stated.
    Missed that, and almost got me crazy.
    Thanks for pointing me at page 10.
  1. Internal pullups on 18F45K22
    By Experimenter in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2014, 21:13
  2. Unknown Processor(18f45k22)
    By Azreel420 in forum mel PIC BASIC Pro
    Last Post: - 15th August 2014, 14:47
  3. PIC 16F74 and PORTE
    By Len in forum General
    Last Post: - 28th May 2012, 13:45
  4. Replies: 9
    Last Post: - 25th July 2006, 05:14
  5. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
