If you are installing from the blue disc, you shouldn't have any problems.
But remember to right-click the install program and "Run As Administrator".
If you are installing from an older Black and White disc, there are a few extra steps to follow.
They must be done in the order shown.
- Right-click the Install program and "Run as Administrator".
. - Enable XP compatibility for the newly installed CodeStudioPlus.exe program.
Tutorial - http://www.sevenforums.com/tutorials...lity-mode.html
. - Run the online update for MicroCode Studio. Being careful to read all the instructions.
You may have to download and rename files to complete the update.
. - Once it has been updated to version 3.0.0.5 (or higher), turn XP compatibility OFF for CodeStudioPlus.exe.
Leaving compatibility turned on will generate run.pif errors.
. - Install MPLAB.
If you have PicBasic Pro version 2.50 or previous then MPLAB 8.15a is the last version you should use.
It's available from ... http://www.melabs.com/support/mplab_old_versions.htm
If you have PicBasic Pro version 2.60 or later, download the latest version from Microchip.
http://www.microchip.com/stellent/id...&part=SW007002
. - In MicroCode Studio, go to View > Compile and Program Options > Assembler tab.
Click the "Find Manually" button and point it to the new MPASM installation ...
C:\Program Files\Microchip\MPASM Suite, for 32-bit windows
C:\Program Files (x86)\Microchip\MPASM Suite, for 64-bit systems
Check the "Use MPASM" check box.
The default PM.exe assembler is a 16-bit program and will not run on 64-bit systems.
On 64-bit systems, all programs must be assembled with MPASM.
MicroCode Studio Plus should now compile in Vista/Win7-32/64.
If you are using the free version of MicroCode Studio, download the latest version (4.0.0.0) from here ...
http://melabs.com/resources/win_ide.htm
Save it to your desktop, then right-click and Run As Administrator.
It's OK to delete the install program when you are done.
