'<FL_PIC18F2550>' '<FL_PBPL>'
DEFINE OSC 48
@ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L ' I Change this, using 20Mhz crystal
@ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
@ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
@ __CONFIG _CONFIG2L, _PWRT_ON_2L & _VREGEN_ON_2L
@ __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
@ __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
' Alias PIC pins and registers for SD/MMC card ' I follow this connections
SD_WE VAR PORTA.4 ' SD card write protect
SD_WE_TRIS VAR TRISA.4 ' SD card write protect direction
SDI VAR PORTA.5 ' SPI data in SD #7
SDI_TRIS VAR TRISA.5 ' SPI data in direction
SCL VAR PORTA.3 ' SPI clock SD #5
SCL_TRIS VAR TRISA.3 ' SPI clock direction
SD_CS VAR PORTC.2 ' SD card chip select SD #1
SD_CS_TRIS VAR TRISC.2 ' SD card chip select direction
SD_CD VAR PORTC.0 ' SD card detect
SD_CD_TRIS VAR TRISC.0 ' SD card detect direction
SDO VAR PORTC.1 ' SPI data out SD #2
SDO_TRIS VAR TRISC.1 ' SPI data out direction
INCLUDE "SDFS.PBP" ' Change extension to PBP
SDC_UseHardSPI = FALSE ' Use hardware SSP port for SPI.
INCLUDE "cdc_desc.bas" ' I have CDC_Desc, DT_INTS-18 and ReEnterPBP.BAS in the same folder
INCLUDE "DT_INTS-18.bas"
INCLUDE "ReEnterPBP-18.bas"
INT_Handler INT_INT, _CNT_PLUS, PBP, yes
INT_Handler USB_INT, _SERVICE_USB, ASM, yes
'START USB AND INTERRUPTS
PAUSE 100 'TIME TO SETTLE
USBINIT 'INITIALIZE USB
USBSERVICE 'SERVICE USB
UIE = $7F 'ENABLE USB INTERRUPTS
UEIE = $9F 'ENABLE USB ERROR INTERRUPTS
PAUSE 500 'MORE TIME
USBINIT
USBSERVICE
@ INT_ENABLE USB_INT
USBSERVICE
@ INT_ENABLE INT_INT
'VARs AND DEFINEs
ADCON1 = 001110
LED VAR PORTA.2
TEXT_TIME VAR BYTE[6]
TEXT_DATE VAR BYTE[6]
TEXT_TEMP VAR BYTE[8]
TEXT_NO_CARD VAR BYTE[9]
MAC_FileName VAR BYTE[11]
B0 VAR BYTE
B1 VAR BYTE
CNT VAR WORD
CIU VAR BYTE 'CARD IN USE
CRON VAR BYTE[11]
CRON_D VAR BYTE[11]
SPACE VAR BYTE[2]
T_BUFFER VAR BYTE[8]
T_ONES VAR BYTE
T_TENS VAR BYTE
T_HUNS VAR BYTE
OUT_TEMP VAR BYTE
ADC_TEMP VAR WORD
S_TEMP VAR BYTE
X_TEMP VAR BYTE
'RTC DEFINES
DS_SCL VAR PORTB.1 'CLOCK
DS_SDA VAR PORTB.2 'DATA
RTC CON 010000
SEC_REG CON $00
CONT_REG CON $0E
CNTRL CON 000000
'RTC VARS
sec VAR BYTE: mins VAR BYTE: hr VAR BYTE: day VAR BYTE
date VAR BYTE: mon VAR BYTE: yr VAR BYTE
'RTC DEC VARS
SEC_O VAR BYTE: SEC_T VAR BYTE: MIN_O VAR BYTE: MIN_T VAR BYTE
HR_O VAR BYTE: HR_T VAR BYTE: MON_O VAR BYTE: MON_T VAR BYTE
DATE_O VAR BYTE: DATE_T VAR BYTE: YR_O VAR BYTE: YR_T VAR BYTE
'SD CARD FILE
FILE_seconds VAR BYTE: FILE_minutes VAR BYTE: FILE_hours VAR BYTE
FILE_day VAR BYTE: FILE_month VAR BYTE: FILE_year VAR BYTE
'SETS THE RTC TO PULSE OUT AT 1HZ
I2CWRITE DS_SDA, DS_SCL, RTC, CONT_REG, [CNTRL]
'SETS FILE NAME TO THE TIME BOARD IS POWERED
'GOSUB READ_RTC
MAC_FileName[0] = "1" '$30+HR_T 'Just made some dummy filename
MAC_FileName[1] = "0" '$30+HR_O
MAC_FileName[2] = "3" '$30+MIN_T
MAC_FileName[3] = "0" '$30+MIN_O
MAC_FileName[4] = "1" '$30+SEC_T
MAC_FileName[5] = "0" '$30+SEC_O
MAC_FileName[6] = " "
MAC_FileName[7] = " "
MAC_FileName[8] = "T"
MAC_FileName[9] = "X"
MAC_FileName[10] = "T"
'BUILD SOME USB TEXT
FOR B0 = 0 TO 5
LOOKUP B0,[" TIME "],B1
TEXT_TIME(B0) = B1
NEXT B0
FOR B0 = 0 TO 5
LOOKUP B0,[" DATE "],B1
TEXT_DATE(B0) = B1
NEXT B0
FOR B0 = 0 TO 7
LOOKUP B0,[" TEMP F "],B1
TEXT_TEMP(B0) = B1
NEXT B0
SPACE[0] = $d
SPACE[1] = $a
FOR B0 = 0 TO 9
LOOKUP B0,[" NO CARD",$d,$a],B1
TEXT_NO_CARD(B0) = B1
NEXT B0
CNT = 60 'I set CNT to 60 for test
'IF THE RTC NEEDS SET GOTO THE SET_RTC ROUTINE AND
'ENTER THE TIME AND DATE. RUN THE CODE ONCE THEN RE-COMMENT.
'GOSUB SET_RTC
'MAIN PROGRAM
CHECK:
IF CNT >= 60 THEN 'NUMBER OF SECONDS
CNT = 0
'GOSUB GET_T ' I disable this line, not read temperature
'GOSUB READ_RTC ' I disable this line, not read rtc
GOSUB USB_DISPLAY
IF (SD_WE = 0) AND (SD_CD = 0) THEN
GOTO SD_WRITE
PWM LED,25,250
USBOUT 3, TEXT_NO_CARD, 10, CHECK
PAUSE 500
GOTO CHECK
'ISRs
CNT_PLUS:
IF CIU = 1 THEN
PWM LED,75,250
TOGGLE LED
LOW LED
CNT = CNT + 1
@ INT_RETURN
SERVICE_USB:
USBSERVICE
@ INT_RETURN
SET_RTC:
yr = $10
mon = $10
date = $09
sec = $00
mins = $52
hr = $02
I2CWRITE DS_SDA, DS_SCL, RTC, SEC_REG, [sec,mins,hr,day,date,mon,yr]
READ_RTC:
I2CREAD DS_SDA, DS_SCL, RTC, SEC_REG, [sec,mins,hr,day,date,mon,yr]
SEC_T = sec & $70
SEC_T = SEC_T>>4
SEC_O = sec & $0F
MIN_T = mins & $70
MIN_T = MIN_T>>4
MIN_O = MINs & $0F
HR_T = hr & $70
HR_T = HR_T>>4
HR_O = hr & $0F
MON_T = mon & $70
MON_T = MON_T>>4
MON_O = mon & $0F
DATE_T = date & $70
DATE_T = DATE_T>>4
DATE_O = date & $0F
YR_T = yr & $70
YR_T = YR_T>>4
YR_O = yr & $0F
CRON[0] = " "
CRON[1] = $30+HR_T
CRON[2] = $30+HR_O
CRON[3] = ":"
CRON[4] = $30+MIN_T
CRON[5] = $30+MIN_O
CRON[6] = ":"
CRON[7] = $30+SEC_T
CRON[8] = $30+SEC_O
CRON[9] = $d
CRON[10] = $a
CRON_D[0] = " "
CRON_D[1] = $30+MON_T
CRON_D[2] = $30+MON_O
CRON_D[3] = "/"
CRON_D[4] = $30+DATE_T
CRON_D[5] = $30+DATE_O
CRON_D[6] = "/"
CRON_D[7] = $30+YR_T
CRON_D[8] = $30+YR_O
CRON_D[9] = $d
CRON_D[10] = $a
FILE_seconds = (SEC_T*10)+SEC_O
FILE_minutes = (MIN_T*10)+MIN_O
FILE_hours = (HR_T*10)+HR_O
FILE_day = (DATE_T*10)+DATE_O
FILE_month = (MON_T*10)+MON_O
FILE_year = (YR_T*10)+YR_O
GET_T:
ADC_TEMP = 0
FOR X_TEMP = 1 TO 20
ADCON0=00000001
GOSUB READ_AD
S_TEMP = ADRESH
ADC_TEMP = ADC_TEMP + S_TEMP
PAUSE 250
NEXT X_TEMP
OUT_TEMP = ADC_TEMP / 20
OUT_TEMP = OUT_TEMP * 13/10
T_HUNS = OUT_TEMP/100
T_TENS = (OUT_TEMP - T_HUNS * 100)/10
T_ONES = OUT_TEMP-((T_HUNS*100)+(T_TENS*10))
T_BUFFER[0] = $30+T_HUNS
T_BUFFER[1] = $30+T_TENS
T_BUFFER[2] = $30+T_ONES
T_BUFFER[3] = " "
T_BUFFER[4] = " "
T_BUFFER[5] = " "
T_BUFFER[6] = $d
T_BUFFER[7] = $a
READ_AD:
PAUSE 50
ADCON0.1=1
WHILE ADCON0.2=1:WEND
USB_DISPLAY:
PAUSE 1
USBOUT 3, SPACE, 2, CHECK
PAUSE 1
USBOUT 3, TEXT_TIME, 6, CHECK
PAUSE 1
USBOUT 3, CRON, 11, CHECK
PAUSE 1
USBOUT 3, TEXT_DATE, 6, CHECK
PAUSE 1
USBOUT 3, CRON_D, 11, CHECK
PAUSE 1
USBOUT 3, TEXT_TEMP, 8, CHECK
PAUSE 1
USBOUT 3, T_BUFFER, 8, CHECK
PAUSE 1
'SD CARD ROUTINES
SD_WRITE:
CIU = 1
SDINIT:
' FSInit initializes the card and reads all the preliminary information from it
GOSUB FSInit
IF (FAT_error != 0) THEN STOP
' Display card directory
GOSUB FINDfirst ' Find first file on card
WHILE (FAT_error = 0)
GOSUB FINDnext ' Find next file on card
WEND
SDFILENAME:
' This section defines a specific short (8.3) filename
' Note that spaces are use in empty elements and must be upper case for Windows
FAT_FileName[0] = MAC_FileName[0]
FAT_FileName[1] = MAC_FileName[1]
FAT_FileName[2] = MAC_FileName[2]
FAT_FileName[3] = MAC_FileName[3]
FAT_FileName[4] = MAC_FileName[4]
FAT_FileName[5] = MAC_FileName[5]
FAT_FileName[6] = MAC_FileName[6]
FAT_FileName[7] = MAC_FileName[7]
FAT_FileName[8] = MAC_FileName[8]
FAT_FileName[9] = MAC_FileName[9]
FAT_FileName[10] = MAC_FileName[10]
FAT_seconds = FILE_seconds
FAT_minutes = FILE_minutes
FAT_hours = FILE_hours
FAT_day = FILE_day
FAT_month = FILE_month
FAT_year = FILE_year+20
SDOPEN_W:
' Open a file for write
FAT_mode = "A" ' Write mode APPEND
GOSUB FSfopen ' Open file pointed to by Byte array FAT_FileName
IF (FAT_error = 10) THEN STOP
SD_WRITE_FILE:
' Write to file
FAT_src[0] = "T"
FAT_src[1] = "I"
FAT_src[2] = "M"
FAT_src[3] = "E"
FAT_src[4] = $d
FAT_src[5] = $a
FAT_src[6] = $30+HR_T
FAT_src[7] = $30+HR_O
FAT_src[8] = ":"
FAT_src[9] = $30+MIN_T
FAT_src[10] = $30+MIN_O
FAT_src[11] = ":"
FAT_src[12] = $30+SEC_T
FAT_src[13] = $30+SEC_O
FAT_src[14] = $d
FAT_src[15] = $a
FAT_src[16] = "D"
FAT_src[17] = "A"
FAT_src[18] = "T"
FAT_src[19] = "E"
FAT_src[20] = $d
FAT_src[21] = $a
FAT_src[22] = $30+MON_T
FAT_src[23] = $30+MON_O
FAT_src[24] = ":"
FAT_src[25] = $30+DATE_T
FAT_src[26] = $30+DATE_O
FAT_src[27] = ":"
FAT_src[28] = $30+YR_T
FAT_src[29] = $30+YR_O
FAT_src[30] = $d
FAT_src[31] = $a
FAT_src[32] = " "
FAT_src[33] = $30+T_HUNS
FAT_src[34] = $30+T_TENS
FAT_src[35] = $30+T_ONES
FAT_src[36] = " "
FAT_src[37] = "F"
FAT_src[38] = $d
FAT_src[39] = $a
FAT_src[40] = $d
FAT_src[41] = $a
FAT_count = 42
GOSUB FSfwrite
SDCLOSE:
' Close file
GOSUB FSfclose
PAUSE 5000
CIU = 0
GOTO CHECK
What do you think I'm missing?
