Pic to Android
Results 1 to 10 of 10
Thread: Pic to Android
    Aug 2009
    Paso Robles California
    Default Pic to Android
    Ok just watched a few videos on Android and usb to android. Did a quick search and found nothing here. Has anybody connected to android phone or tablet via usb and do you have any code examples (something very simple) that I could look at?
    Default Re: Pic to Android
    I haven't yet, maybe these might help, found them using ANDROID in search box at top right (use the Live Search box way at top):
    http://www.picbasic.co.uk/forum/showthread.php?t=14812
    http://www.picbasic.co.uk/forum/showthread.php?t=13985
    http://www.picbasic.co.uk/forum/showthread.php?t=15460
    Please post back details when you have something working, I'm curious to see these work too.
    It depends on what you want to do. If the idea is to use the Android as a terminal for sending / receiving data or a remote display, or a controller for your pic project, I think its far easier to go with the Android's built-in bluetooth, rather than USB. Just use any Bluetooth serial module on the pic side (do a google for 'Linvor' on ebay) and you're ready to go. No software needed on the pic side, besides the usual UART commands; on the ANdroid you could run a terminal emulator like Blueterm or a XML scripted controller like Bluescript, both available on the Market for free.
    Anand Dhuru
    Aug 2009
    USB looks fairly easy if you use the 24f part, microchip has code already made for the 24f part, and android has built in support for this chip. but I will need to buy software for programming the android and the microchip test board setup to play with there goes some more money.
    More info please.
    Aug 2009
    see if this link works there are a number of video's from google on this.
    Ok, now I remember seeing something about this.
    Is this the test board you plan to use?
    http://www.microchip.com/stellent/id...cName=en553673
    Aug 2009
    sorry that was not the correct one I will try and find the other on but here is the microchip board with examples
    Aug 2009
    Yes it is maybe
    Aug 2009
    here is another vid still not the one I watched dam should have of book marked it
