in this code i want to increase duty until Feedback is equal to 3, then to break the loop after feedback is equal to 3, then to take this value of duty which made feedback equal to 3 out of loop and to continue to output this constant duty.
In Pic basic is it possible to use this break statement as in c language, if yes how? If no help me alternative way to solve this problem, thanx in advance
clear
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
' Duty cycle value (CCPR1L:CCP1CON<5:4>)
Feedback var word
ADCON1=%00000010
duty VAR WORD ' Duty cycle value (CCPR1L:CCP1CON<5:4>)
TRISA = %11111111
TRISB = %11111111
TRISC = %11111011 ' Set PORTC.2 (CCP1) to output
CCP1CON = %00001100 ' Set CCP1 to PWM
T2CON = %00000101 ' Turn on Timer2, Prescale=4
' Use formula to determine PR2 value for a 1KHz signal,
' 4MHz clock, and prescale=4. (4E6/(4*4*1E3))-1=249
PR2 = 249 ' Set PR2 to get 1KHz out
' Use formula to determine CCPR1L:CCP1CON<5:4> value for
' ends of range 20% to 80%. (249+1)*4*0.2=200 (20% value)
' (249+1)*4*0.8=800 (80% value)
duty = 0 ' Set duty cycle to 0%
mainloop:
adcin 0, feedback
CCP1CON.4 = duty.0 ' Store duty to registers as
CCP1CON.5 = duty.1 ' a 10-bit word
CCPR1L = DUTY >> 2
duty = duty + 1 ' Increase duty cycle
' Since the total sweep of duty is 1000 (1000-0) and
' we are adding 1 for each loop, that results in 60
' steps min to max. 1 second divided by 1000 = 1mS
Pause 1
' Pause 1/60 of second
IF (feedback => 3) Then
' *****break the loop****
GoTo mainloop ' Do it forever
CCPR1L = DUTY >> 2
