Decoding Pulse Telephone
Results 1 to 13 of 13
    Default Decoding Pulse Telephone
    I need to decode 3 digits from a dial telephone.
    It pulses at a rate of aprox. 10Hz and as many pulses as the digit dialed.
    I need to decode say a number like 100.
    The problem is thatthe user does not always dial at the same time space each digit.
    Also if wrong digit are dialed, it should reject them (obviously).
    The idea of using Pulsin is rejected because it times out pretty quickly. Maybe timer1 is good idea, but I have to consider also the time between digits.
    Any idea welcome.
    Sep 2009
    Default Re: Decoding Pulse Telephone
    I had somewhere rotary dialer from old phone, and first pulse should be longer than rest of them(I think that phone with IC do same thing when switched to pulse dialing).
    First hook up phone to scope, you need 100R resistor 12V PSU and phone. So dial few number and get timing for first pulse and period for rest of them.
    Logic would be wait for long pulse, than count impulses, with timeout period that is twice long as period that impulses are repeated. And reset timeout on each received pulse. Create something like SERIN works. It should be easy.
    For measuring time you can use timer, or loop with pause 1 inside and count how many time loop are repeated, or timer with interrupt, and in ISR just increment some variable, etc...
    most dials have a 66/33 mark/space ratio and fixed impulse rate of 10 impulses / second , there is also a fixed minimum interdigital pause between digits built into the dial mechanism . a pause in dialing longer than the 66/33 ratio will always indicate a new digit or the end of dialing
    Thanks for the info. Did not knew there is a 66/33 ratio. Soon the scope will reveal the case.
    Feb 2003
    Its a long time since I did my BT apprenticeship (40 years!) and I no longer have any of my notes but this thread triggered something in my brain about the minimum Inter Digit Pause being 450mS as that is the amout of time that was needed for a strowger switch to detect the end of the dialled digit and sweep the bank looking for a free outlet. If its a rotary dial tone you wont be able to get the minimum below about 1 second as thats how long it takes to turn the dial for the next digit but if its Pulse Dial push button phone then the minimum Inter Digit Pause will be determined by the dialling chip in the phone.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    OK, Thanks Keith.
    The first pulse does not seem to be different than the rest.
    The pause between digits is between 500-750ms according to the phone.
    Each pulse is 1Hz or 600/400msec ratio.
    Aug 2003
    If I recall correctly there’s a switch to tell the dial is in the home position to tell it was the end of a set of pulses,
    or that a set of pulses is about to arrive if you want to look at it that way.
    You can avoid any debounce hardware. All you have to do is pick whether you’re going to count rising or falling edges,
    and look for a decent consecutive samples of the switch in one position, and then the same number of samples indicating
    the switch is in the opposite position to qualify a rising or falling edge of the dial switch.
    Thats interesting. I see two pair of wires coming out of the dial. So one pair is sure the digit pulser, the other might be exactly that, the home position. Maybe they used that to mute the earpiece?
    Sure I can make good use to it.
    Aug 2003
    The other wire might be for the rotary switch normally open and closed positions.
    I found code I did if it helps. This was to time dialling zero (ten) to calibrate a dial.
    The LED should land int he middle, but most dials are a little off.
    It happens to know the number dialled too, though the hardware wasn’t for displaying it.
    '*                          [email protected]                               *
    '*                             Brek Martin 2013-14                                 *
    DEFINE OSC 20								' but we are really using 8 MHz
    DEFINE NO_CLRWDT							' watchdog is cleared manually
    LCD_DATAUS CON 50							' LCD timing
    LCD_COMMANDUS CON 2000						'
    'INTCON.4 = 1									'enable portb.0 interrupt
    'OPTION_REG.6 = 0								'interrupt on falling edge of portb.0
    INCLUDE "Elapsed.bas"							'
    ' execution time!
    CMCON = 7	' set portb to digital
    trisb.7 = 0	' set LED outputs
    trisb.6 = 0	'
    trisb.5 = 0	'
    trisb.4 = 0	'
    trisb.3 = 0	'
    trisb.2 = 0	'
    trisb.1 = 0	'
    trisb.0 = 1 ' set rotary dial switch input (pulse)
    trisa.1 = 1 ' set rotary dial switch input (home)
    @ clrwdt			; clear watchdog timer manually
    flashrate var byte
    timea var byte
    index var byte	' declare values for LED test startup
    indexb var byte
    bpattern var byte
    dialcount var byte
    oldlast var byte
    errstart:
    bpattern = %00000001
    dialcount = 0
    flashrate = 8
    timea = 64
    FOR indexb = 0 TO 6  ' fancy led test startup
    FOR index = 0 TO 6
    @ rlf _bpattern
    portb = bpattern
    pause flashrate
    NEXT index
    FOR index = 0 TO 6
    @ rrf _bpattern
    portb = bpattern
    pause flashrate
    NEXT index
    flashrate = flashrate - 1
    NEXT indexb
    portb = 0
    extint = 0			'reset external variables
    freq = 0
    ticcnt = 0
    ready var bit		'declare internal variables
    ready = 0
    counting var bit
    counting = 0
    thetime var byte
    thetime = 0
    lasta var byte'		'bit to check for last rising edge
    lasta = 0
    Gosub ResetTime		'Reset Time 00:00:00
    cycle:				' main routine - 3D Cube user program
    IF porta.1 = 1 && counting = 0 THEN
    portb = %11111110 ' dial not home indicator
    ready = 1 ' set ready to count time status
    thetime = 0
    bpattern = 0
    IF counting = 1 THEN
    IF portb.0 = 0 THEN
    portb = %11111110 ' flash LEDs on for break
    pauseus 50
    portb = 0
    portb = 0		' flash LEDs off for make
    portb = 0
    IF ready = 1 THEN ' check ready to count status
    IF portb.0 = 0 THEN ' look for first falling edge
    gosub StartTimer	'start clock timer
    thetime = 0
    dialcount = 0
    timea = 64
    counting = 1
    ready = 0  ' lock routine
    IF counting = 1 THEN ' check counting and dial at home position
    IF portb.0 = 1 && lasta > 3 THEN ' look for last rising edge otherwise is overwritten
    thetime = Seconds*100
    thetime = thetime + Ticks
    oldlast = lasta
    IF portb.0 = 0 THEN		' dial switch debounce in software
    lasta = lasta + 1
    lasta = 0
    IF lasta < oldlast THEN ' increment dial pulse counter
    dialcount = dialcount + 1
    IF porta.1 = 0 THEN
    gosub StopTimer
    counting = 0
    timea = 10
    IF dialcount < 10 THEN	' check that zero was dialed
    goto errstart			' or error condition
    IF thetime > timea && thetime < 75 THEN	' LED time display
    bpattern = %00000010 ' dial too fast
    IF thetime > 74 && thetime < 85 THEN
    bpattern = %00000100
    IF thetime > 84 && thetime < 95 THEN
    bpattern = %00001000
    IF thetime > 94 && thetime < 105 THEN
    bpattern = %00010000 ' ideal time
    IF thetime > 104 && thetime < 115 THEN
    bpattern = %00100000
    IF thetime > 114 && thetime < 125 THEN
    bpattern = %01000000
    IF thetime > 124 THEN
    bpattern = %10000000 ' dial too slow
    portb = bpattern
    pauseus 500
    portb = 0
    goto cycle		' end main routine - do the next cycle
    Sep 2010
    Las Vegas, NV
    Though I doubt it, European phones may be different than in the USA but here in the USA only two wires, a pair, are needed for a phone to work.
    The other pair at one time was used for enhancements and power. Those old phones often had several incandescent light bulbs that wouldn't allow the main line to function because the current draw was excessive. Typically nowadays those wires are used for a second line inside the house.
    I think the home position you articulate is really time. If the handset is on the phone long enough the circuit resets and waits for the pulses or the tones. When I was younger you were cool if you didn't use the dial to call someone. You had to be talented enough to bang on the phone cradle the correct number of times to dial a phone. Ah the good old days.
    I'm pretty sure all the pulses are the same time on/pause ratio. You just need to count the number of pulses and not wait too long to dial.
    Feb 2003
    The dials in British phones had 5 contacts. 2 of them were the pulsing contacts which were normally closed and pulsed open for the dial pulses. The other three contacts were normally open and are referred to as the "Dial Off Normal" contacts. They placed a short across the earpiece to prevent acoustic shock and also a short across the carbon granule microphone to prevent the back EMF surges from welding the granules together.
    http://www.britishtelephones.com/howdial.htm
    Keith
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Aug 2003
    Yes only two wires are needed for the phone in Australia too. I'm assuming there's access here to only use the dial mechanism.
    None of our phones have an even make/break ratio though. It's maybe because the relays at the other end will close
    quicker than they will open.
    Old exchange equipment was the reason I was tasked with calibrating the dials.
    A prettier example for counting the digits using the same method here:
    OK, this is what I came up for decoding rotary dialer. It reads and decodes the pulses and compares 3 digits from the EEPROM. If one has different needs just change the arrays accordingly.
    clear
    read 0,array[0],array[1],array[2]    'array holds the stored digits to compare.
    'wsave   var byte $20 system    'depends on the PIC used
            INT_Handler     TMR1_INT,   _Timer1,     PBP,    yes
        INT_CREATE
    Timer1:
        time=time+1      'Interrupt every 0,131msec for a 4MHz PIC clock
        if time>7 then   'time resets every 0,8 sec approximately
            time=0
    @ INT_RETURN
    digit[0]=0:digit[1]=0:digit[2]=0    'clear array every time it loops here
    for i=0 to 2                      'three digit counter. Change this for more
    get_digit:
        while !dial:pause 10:wend    'wait for dial rotation
    get_next
        time=0
        while dial
            if time>1 then main    'every digit takes around 10 ms. If times gets 1
        wend                            'then it sure timed out
        digit[i]=digit[i]+1         'increment digit value
        time=0                        'reset time variable
        while !dial                   'wait for next high edge
            if time>4 then next_digit    'if time is more than 500-600ms then
        wend                          'next digit has arrived
        goto get_next
    next_digit:
        if digit[i]<>array[i] then error    'if digit and array are different then wrong number dialed
        next i
        high green:pause 1000:low green:goto main      'SUCCESS!
    error:
        high red:pause 1000:low red:goto main            'WRONG DIGITS!!!
  1. Telephone interface questions
    By Skarr11 in forum Schematics
    Last Post: - 4th December 2010, 23:08
  2. Melabs Labx??? Evaluationboard for telephone applications
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 18th October 2010, 20:40
  3. Lab-XT telephone connection question
    By percychen in forum Schematics
    Last Post: - 6th February 2010, 23:18
  4. Pulse Decoding
    By Freman in forum General
    Last Post: - 2nd June 2008, 21:31
  5. DTMF decoding
    By maria in forum mel PIC BASIC Pro
    Last Post: - 12th May 2004, 15:11
