MEL PIC BASIC Manual
+ Reply to Thread
Results 1 to 13 of 13
    Apr 2003
    Cambridge - UK
    igeorge's Avatar
    igeorge Guest
    Default link is dead
    I can not get to the manual as the link is dead. Do you have an other link ?
    Ion
    badrad's Avatar
    badrad Guest
    I think the pdf manuals have been removed by MeLabs, however the html version is on-line here for the PBP version...
    http://www.microengineeringlabs.com/...ces/pbpmanual/
    and here for the plain vanilla...
    http://www.microengineeringlabs.com/...ces/pbcmanual/
    Melanie
    igeorge's Avatar
    igeorge Guest
    Thank you Melanie. What is the actual verion of the Pic Basic Pro ?
    What is the actual version of PBP, because on the posted link it was mention 5 or something similar, but the version which i bought a week ago it is 2.45 ?!?!
    Ion
    Hi igeorge,
    current version is indeed 2.45. As i read in your pots, you buy it from Reynolds Electronic (rentron.com). Be sure that Bruce will not offers less than the lastest version.
    regards
    igeorge's Avatar
    igeorge Guest
    I cheked my version by doing an update which returned the message:
    You have the latest version, no update available.
    Merci beaucoup
    Hi igeorge,
    you do your check in MicroCode Studio. It doesn't check for the PicBasic Pro version. Only for microCode studio Version.
    bienvenu
    That's the manual Revision I believe which on my last .pdf dowload was 5.02.
    This page gives you the current Version History...
    http://www.melabs.com/support/upgrade.htm
    Do check with the MeLabs website regularly for Updates, Upgrades, downloads, etc etc.
    igeorge's Avatar
    igeorge Guest
    Thank you Melanie,
    I got the link and the manual as you sugested.
    Do you know where i can get the link for the pdf version ?
    Thank you
    Ion
    igeorge's Avatar
    igeorge Guest
    Melanie,
    I know it is not the place for this post here, but as you will recieve notification on your mail i will ask for help.
    On the schematic forum i put a post as:
    "Newbie needs help"
    I can not make the chip to run in its own, nor i know how to make a chip to use it in a stand alone PCB.
    Can you please , have a look and switch on the light in this problem?
    Thank you
    Ion
    P.S. I am just 5 days old with Pics and Flash-Lab.
    I just give up with stamps and try to get more from PICs
    pdf's seem to have been removed as I mentioned earlier.
    Questions regarding why should best be directed to MeLabs.
    Default THE PBP Manual
    Looking for the 2.60 pdf Manual ???
    http://melabs.com/downloads/PBP_Manual_0609_260.pdf
  1. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 13:18
  2. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 18:05
  3. How to use 93C46 Type EEPROM using PIC Basic PRo
    By in forum mel PIC BASIC Pro
    Last Post: - 1st April 2003, 04:07
  4. Help with MPASM and PIC Basic
    By johngb in forum mel PIC BASIC Pro
    Last Post: - 21st February 2003, 13:07
