Data Logging
Results 1 to 8 of 8
Thread: Data Logging
    barkerben's Avatar
    barkerben Guest
    Default Data Logging
    I'm putting together a system to talk to a GPS board I have. It will do various things, such as output to an LCD etc. I wanted to do some data logging - record waypoints, track position every x seconds, etc.
    Serial EEPROM seems to be the way to go. But 1 Million write cycles is not neccesarily as much as it sounds if you are recording a few bytes every few seconds. Does anyone have any thoughts...?
    Cheers,
    Ben
    barkerben's Avatar
    barkerben Guest
    Default Compact flash
    I found a few other posts on this site. I also found a site here:
    http://www.mikroelektronika.co.yu/en...ook/08.htm#8.3
    This talks about writing to CF using a POC, but seems to be for a different distribution of Basic...?
    Mar 2005
    Iowa, USA
    Lightbulb
    Look into FRAM from www.ramtron.com
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Lightbulb
    Ben, every BYTE can be written to 1 million times. Surely you don't fill your entire memory every few seconds.
    barkerben's Avatar
    barkerben Guest
    Ah... every byte. That makes a lot more sense, now I come to think about it!
    Interfacing a serial EEPROM to a PIC should be quite simple. I still need to find an easy way of getting the data out of the eeprom and onto a PC, which is why the CF idea seemed nice. But probably far more complicated...
    Ben
    Feb 2004
    Germany
    Ben,
    have you had a look at This Thread ?
    regards
    Ralph
    barkerben's Avatar
    barkerben Guest
    Thanks - I found that a few minutes ago - it seems very thorough!
    Cheers,
    Ben
    barkerben's Avatar
    barkerben Guest
    Yeah. An EEPROm would certainly store the data - but accessing it on a PC once it has been recored seems slightly more involved. An advantage of using something like a formatted flash card is it is possible to just plug it in and read what's there.
    The disadvantage seems to be the added complexity of circuitry and programming to achieve this...
  1. Using Nokia LCD
    By BobP in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    By Don Mario in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 00:56
