Indexing Port Pins
Results 1 to 7 of 7
    Default Indexing Port Pins
    Melanie posted an excellent article on indexing bits, bytes, words, etc. here
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    Someone asked how to index port pins in a similar way, so here's one way.
    Port file register addresses are sequential. For instance on the 16F876A file
    register address for porta is at location 05h, portb is at 06h, and portc is at
    07h. All you need is a pointer to the base of the bit index.
    Example; SYMBOL PORT_PIN = PORTA ' <- start of bit index or pointer
    Now using something like this, you can index all port bits.
    X VAR BYTE ' For loop & bit index pointer
    ADCON1 = 7 ' All digital
    PORTA = 0   ' Clear all port pins
    PORTB = 0
    PORTC = 0
    TRISA = 0   ' Make them all outputs
    TRISB = 0
    TRISC = 0
    FOR X = 0 TO 23
      PORT_PIN.0[X] = 1  ' Set all porta, portb, and portc pins high
    NEXT X
    There aren't 8 pins on porta that can go high, but it's still an 8-bit file register
    so we have to treat it as 8-bit and index from 0 to 23 for 24-bits total.
    You can do this on any PIC to index all port pins individually just using porta
    as the starting index pointer.
    PBP doesn't perfom bounds checking, so you can get away with indexing
    out of bounds.
    Note that also means you could write to a register you may not intend to if
    you're not careful.
    You could drop porta, and just use portb as the starting address also.
    SYMBOL PORT_PIN = PORTB
    PORTB = 0
    PORTC = 0
    TRISB = 0
    TRISC = 0
    FOR X = 0 TO 15 ' 16-bits total
      PORT_PIN.0[X] = 1  ' Set all portb, and portc pins high
    NEXT X
    Last edited by ScaleRobotics; - 5th December 2010 at 18:13. Reason: added code tags
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Istanbul
    Default Indexing mixed port pins
    In addition to Bruce's nice examples, and in connection with Melanie's explanations, mixed port pins can be driven in a sequence with the code below. The code is for demonstration purposes and quite easy to figure out.
    TRISA  = %00000000
    TRISB  = %00000000
    TRISC  = %00000000
    TRISD  = %00000000
    TRISE  = %00000000
    ADCON1 = %00000000
    PORTA  = 0
    PORTB  = 0
    PORTC  = 0
    PORTD  = 0
    PORTE  = 0
    MYPORT VAR BYTE
    LOOP   var BYTE
    '======Say you have to drive
    'these pins in a sequence. They are all mixed.
    RelayA  VAR PORTA.1
    RelayB  var PORTA.3
    RelayC  var PORTB.5
    RelayD  var PORTC.0
    RelayE  var PORTD.2
    RelayF  var PORTD.4
    RelayG  var PORTE.0
    MYPORT=0
    Start:
        for loop=1 to 7
          myport.0[loop]=1  'High
          gosub driveport
          myport.0[loop]=0  'Low
          gosub driveport
        next loop
    goto start
    DrivePort:
        RELAYA = myport.1
        RELAYB = MYPORT.2
        RELAYC = MYPORT.3
        RELAYD = MYPORT.4
        RELAYE = MYPORT.5
        RELAYF = MYPORT.6
        RELAYG = MYPORT.7
    Hope it can be some help to some members.
    Regards.
    brighton
    Exclamation
    Hi Bruce / sayzer
    Just being reading your interesting posts about port indexing
    and wanted to know if it was posible to map a variable to different ports
    example say like using a word variable to control the 16bits below
    How to i go about this? Is it possible ?
    RB7 = //MSB
    RB6
    RB5
    RB4
    RB3
    RB2
    RB1
    RB0
    RA0
    RA1
    RA2
    RA3
    RD0
    RD1
    RD2
    RD3 //LSB
    Hope you can help
    Isaac
    Hi Isaac,
    See this thread for some ideas: http://www.picbasic.co.uk/forum/showthread.php?t=4074
    -Bruce
    tech at rentron.com
    Jan 2006
    Istanbul
    Quote Originally Posted by isaac
    Hi Bruce / sayzer....
    ...using a word variable to control the 16bits below
    How to i go about this? Is it possible ?...
    I do not think you can drive the ports or port pins directly by using alias on them via a the bits of a WORD or BYTE variable.
    For example,
    MYPORT VAR WORD
    PORTA.1 VAR MYPORT.0 is an incorrect arrangement.
    MYPORT.0 VAR PORTA.1 is also incorrect.
    PORTB VAR MYPORT.HighByte incorrect.
    PORTA VAR MYPORT incorrect
    But,
    PORTB = MYPORT
    or
    PORTB = MYPORT.HighByte or PORTB = MYPORT.LowByte can be ok!
    But anyway, in addition to the link that Bruce posted, here I posted an example with the port pins you listed.
    See if it is what you needed.
    'Assuming you have the ports set up.
    Loop    VAR BYTE
    MYPORT  VAR WORD
    MYPORT = 0
    GOSUB DriveMeCrazy  'Pull all pins low.
    Start:
            FOR LOOP = 0 TO 15
                MYPORT.0[LOOP] = 1          'HIGH
                GOSUB DriveMeCrazy
                PAUSE 1000                  'Give it a pause as an example.
                MYPORT.0[LOOP] = 0          'LOW
                GOSUB DriveMeCrazy
            NEXT LOOP
            GOTO START
    DriveMeCrazy:
        PORTB.7 = MYPORT.15
        PORTB.6 = MYPORT.14
        PORTB.5 = MYPORT.13
        PORTB.4 = MYPORT.12
        PORTB.3 = MYPORT.11
        PORTB.2 = MYPORT.10
        PORTB.1 = MYPORT.9
        PORTB.0 = MYPORT.8  'From here to above, "PORTB = MYPORT.HighByte" may also be ok.
        PORTA.0 = MYPORT.7
        PORTA.1 = MYPORT.6
        PORTA.2 = MYPORT.5
        PORTA.3 = MYPORT.4
        PORTD.0 = MYPORT.3
        PORTD.1 = MYPORT.2
        PORTD.2 = MYPORT.1
        PORTD.3 = MYPORT.0
    brighton
    Thanks Bruce /sayzer
    Your examples did help me get it sorted
    you both have being great
    Isaac
    Default Re: Indexing Port Pins
    Update: Cleaned up logic so LEDs always get same current no matter how many are in use.
    When you need to blink a lot of LEDs:
    Here's the results of a current test using 32 LEDs on a 18F44K22 using internal oscillator at 64MHz.
    portLedA    var     PORTA       ' Define Ports
    portLedB    var     PORTB
    portLedC    var     PORTC
    portLedD    var     PORTD
    portLedE    var     PORTE
    byteLoop    VAR     byte        ' Define variables
    byteDelay   VAR     byte
    byteActiveA var     byte        ' Define active pins
    byteActiveB var     byte
    byteActiveC var     byte
    byteActiveD var     byte
    byteActiveE var     byte
    byteRXA     var     byte        ' Define RX data
    byteRXB     var     byte
    byteRXC     var     byte
    byteRXD     var     byte
    byteRXE     var     byte
        portLedA = %00000000        ' Initialize Leds off
        portLedB = %00000000
        portLedC = %00000000
        portLedD = %00000000
        portLedE = %00000000
     byteActiveA = %11111110        ' Determine Active pins     Pin A.0 not used
     byteActiveB = %11111111
     byteActiveC = %00111111                                  ' RX / TX in use
     byteActiveD = %11111111
     byteActiveE = %00000111                                  ' MCLR input only
         byteRXA = %11111110        ' RX data from Master PIC
         byteRXB = %11111111
         byteRXC = %00111111
         byteRXD = %11111111
         byteRXE = %00000111
    byteDelay    = 35               ' Tweak this value to control current and frequency
    ' 1 LED active        668 Hz     2.7 mA LED    14.2 mA circuit
    ' 32 LEDs active      668 Hz     2.7 mA LED    99.0 mA circuit
    ' Using 2N2222 NPN transistor, 4K7 base with 680K pull-down,
    '       LED direct to collector from 5VDC.
    mainloop:
        For byteLoop = 0 to 7                       ' Go through 8 bits
            if byteActiveA.0[byteLoop] = 1 then     ' Check if pin is used
                portLedA.0[byteLoop] = byterxA.0[byteLoop]
                PAUSEUS byteDelay
                portLedA = %00000000                ' Faster than setting bit to 0
            if byteActiveB.0[byteLoop] = 1 then
                portLedB.0[byteLoop] = byterxB.0[byteLoop]
                PAUSEUS byteDelay
            if byteActiveC.0[byteLoop] = 1 then
                portLedC.0[byteLoop] = byterxC.0[byteLoop]
                PAUSEUS byteDelay
            if byteActiveD.0[byteLoop] = 1 then
                portLedD.0[byteLoop] = byterxD.0[byteLoop]
                PAUSEUS byteDelay
            if byteActiveE.0[byteLoop] = 1 then
                portLedE.0[byteLoop] = byterxE.0[byteLoop]
                PAUSEUS byteDelay
        Next byteLoop
        Goto mainloop           ' Go back to loop and blink LEDs forever
    Use byteActiveA-E variables to determine which bits you want toggled.
    Use byteRXA-E variables to receive bits from a Master PIC.
    Use byteDelay variable to tweak current and LED brightness.
    For my testing, MCLR (can only be input), RX/TX (needed) and A0 (unused) were disabled.
    Last edited by Demon; - 6th January 2014 at 05:48. Reason: picture and updated code
  1. Pointers To Port Pins ?
    By BitHead in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2009, 20:38
  2. Change On Interrupt, PIC16F884
    By elec_mech in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 17:25
  3. Another question RE port line indexing
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 7th August 2007, 15:23
  4. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 17:27
  5. PIC PORT 'special' pins
    By barkerben in forum General
    Last Post: - 18th January 2005, 21:40
