Newbie - 16F628A and switch latching
Page 1 of 2 12 LastLast
Results 1 to 40 of 46
    malc-c's Avatar
    malc-c Guest
    Default Newbie - 16F628A and switch latching
    Hi all,
    My first post so be gentile with me
    My first project using PBP is for my 12 year old son's model railway. I'm using a 16F628A with the internal 4Mhz OSC as timing is not an issue (and the internal OSC is claimed to be very precise anyway). The project is not rocket science, simply to detect a train via the momentarly activation of a reed switch. This pulse then turns on an LED which is latched on until the same reed switch is activated again.
    I have two problems:
    1) - The latching is not clean, in that sometimes the LED brightens and remains on when it should be off, or when off it is turned on by the reed switch, but fails to latch
    2) - I'm using WinPIC pro to program the PIC. I have set the PIC up for internal OSC no clock out in the code, but I have to change the settings from XT to RC noClockout in the Winpic application. Is the an issue with the Winpic application, or the code (which compiles OK)
    Anyway, here is my code.
    @INTRC_OSC_NOCLKOUT
    @WDT_ON
    @PWRT_ON
    @MCLR_OFF
    @BOD_ON
    @LVP_OFF
    @CPD_OFF
    @PROTECT_OFF
    CMCON=7
    TRISB=%11101111         'set RB6 as output and the rest input
    SW var PORTB.0          'switch input pin 6 (RB0)
    LED1 var  PORTB.4       'LED1 on pin 10 (RB4)
    Swset var bit
    low led1                'RB4 set to LOW (LED1 is off)
    Swset=0                 'Var swset is set low
    if SW=0 then            'If switch is LOW (Grounded) then
    Toggle Swset            'change swset from 0 to 1
    pauseus 200             'debounce delay
    If Swset=1 then         'if swset is 1
    high led1               'then turn on RB4 (and hence the LED)
    low led1                'else, LED is off
    Goto Main               'go back and keep checking
    The reason I've only configured one output on port B is purely for testing..once I have this sorted, RB0, RB1, RB2 and RB3 will all be switch inpts, with RB4 - RB7 their coresponding outputs (we have 4 sidings to monitor )
    TIA
    Malcolm
    Your debounce delay is too short... swap PAUSEUS for a straight PAUSE. 200mS is neither here nor there in the great scheme of a train moving past your reed switch, whereas in 200uS which you have currently, the train would barely have moved a fraction of a millimetre... With some experimentation, you might find that PAUSE 50 will do...
    malc-c's Avatar
    malc-c Guest
    Thanks for the reply,
    I had played with the debounce pause time, but only by a 100's of a uS
    I'll increase the delay and see how I get on.
    Many thanks
    Malcolm
    Hi Malcolm. One suggestion is to make all unused ports as outputs. This helps in noisy environments as electric motors drive PIC's crazy even with a separate supply. Make sure portb.0 is held high with a resistor not too high in value. I once had a small hobby motor drive my PIC crazy until I went down to a 1K resistor as a pullup.
    CMCON = 7
    TRISA = 0
    TRISB = 0 'MAKE ALL OUTPUTS
    PORTA = 0
    PORTB = 0 'ALL OUTPUTS LOW
    INPUT PORTB.0 'RB0 SWITCH INPUT
    MAIN:
    NAP 0 'REDUCE CURRENT DRAIN ON BATTERY
    IF PORTB.0 = 0 THEN CHANGELED 'IF REED SWITCH CLOSED CHANGE LED STATE
    GOTO MAIN
    CHANGELED:
    TOGGLE PORTB.4 'CHANGE LED STATE
    WAITFORRELEASE:
    PAUSE 1000 'WAIT A SECOND
    IF PORTB.0 = 0 THEN WAITFORRELEASE 'WAIT HERE FOR REED TO OPEN
    GOTO MAIN
    malc-c's Avatar
    malc-c Guest
    Hi Peter,
    Thanks for the advice and I'll make port A all output as I'm only using port B. Oh and yes the inputs on the switches are tied high via a 10K resistor.
    Talking You ..... again !!!
    Hi,Malc
    Have a look to the " BUTTON " command ...it is really very powerful for such application.
    Add a DEFINE BUTTON_PAUSE 200 at the top of your program if you want a debounce time of 200 ms ( max 255 ms ...) ... that's all !
    read you soon !!!
    PS; if not already done, download this : http://www.melabs.com/downloads/pbpm304.pdf
    THE reference manual !!!
    Microcode studio : http://www.melabs.com/downloads/mcs2300.zip
    malc-c's Avatar
    malc-c Guest
    Hee hee - fancy seeing you here
    Yes I have downloaded the manual, and had it open last night whilst I was developing the program, and as manuals go its really good to get newbies like myself up and running.
    Must admit, that I'm having more fun (and luck) with PBP than I did with JAL. PBP seems more logical in its commands and the structure of using them.
    Alain, let me into a secret, is that Melanie in her avitar... brains as well as beauty - wow !!
    Wink The Forum' Highest secret ...
    Quote Originally Posted by malc-c
    In fact, Mel is some like Charly in the "Charly's girls" TV series ... I do not think anyone on this forum knows her real appearance ...
    We only know she says she likes to wear leather clothes at night, and is a bit bored about charming guys hoping to get something from her brain ...
    May be she'd love to find a bunch of red roses and some Champagne at her door rather than the New up to date Compiler ....
    Talk to her gently, and she'll give you the best from her ...
    That's part of what I understood here ... not to break the magic.
    There are those that have sent boxes of red roses...
    ...and there are those that have sent boxes of chocolates...
    ...boxes of diamonds are a little slower in coming - but I'm working on it...
    ...and there are those that have seen a little more of me than others (I seldom refuse an invite to dinner - especially if you're buying - but can you afford a genuine up-town girl?) *smiles*
    ...and Yes, that's really me in the avatar... if you're real nice I just might change it for a while to something more sophisticated - but I'm always worried that I'll distract you from your work (or play)...
    Quote Originally Posted by Melanie
    I have a feeling of what it could be Maybe i'm in the 3rd category ... LOL easy to start some rumor here
    BTW Melanie, if you change your Avatar to 'something more sophisticated', i feel that some end-of-class student here could be shocked OR spam your PM! May i bet on the second one
    My PM is already spammed...
    Dear Miss Whiplash... Thank you for last nights session... I won't be able to sit down for a week, but it was worth every minute... PS My PIC still doesn't work.
    Now, now Steve... people might get the wrong idea on how you ended up in hospital...
    malc-c's Avatar
    malc-c Guest
    Default lets get this back on topic before I need a cold shower !
    I'm hoping that you guys and Miss whippy, sorry Mel can tell me why the following code won't work correctly.
    Having managed to sort out the delay for the debounce I had each LED bing turned on, latched and turned off by activation of the corresponding reed switch - Great !
    However I now want to evolve the code so that the following happens. The siding has the buffer at the left, and trains enter from the right. A reed switch (sw1) is placed at the start of the siding (on the right), a train enters the siding and activated sw1 and LED1 is lit. The train continues to the end of the siding where it activates the second reed switch (sw2) and thus LED2 is lit, and the operator shuts off the power. So far so good.
    Now the operator can re-arrange the train and place the loco at the other end ready to go back on the main layout. When it does sw1 is then activated again, but this time I need it to clear both LED1 and LED2. Ok I thought, lets simply have a new varible (swset5) that is toggled only when swset1 and swset2 are high.. but it won't work. activating sw1, then sw2, then sw1 again just turns off LED1, LED2 remains lit
    Here is my code (I've yet to try the BUTTON command, but maybe that will happen when I come to tidy up the code ??)
    @INTRC_OSC_NOCLKOUT
    @WDT_ON
    @PWRT_ON
    @MCLR_OFF
    @BOD_ON
    @LVP_OFF
    @CPD_OFF
    @PROTECT_OFF
    CMCON=7
    TRISB=%00000011         'set RB0 & 1 as input and the rest output
    SW1 var PORTB.0          'switch input pin 6 (RB0)
    SW2 var PORTB.1          'switch input pin 7 (RB1)
    LED2 var  PORTB.5       'LED1 on pin 11 (RB5)
    Swset1 var bit
    Swset2 var bit
    Swset5 var bit
    low led1
    low led2
    Swset1=0
    Swset2=0
    swset5=0                'Var swset is set low
    if SW1=0 then            'If switch is LOW (Grounded) then
    Toggle Swset1            'change swset1 from 0 to 1
    pause 500                'debounce delay
    if SW2=0 then            'If switch is LOW (Grounded) then
    Toggle Swset2            'change swset2 from 0 to 1
    If Swset1=1 then         'if swset1 is 1
    If Swset2=1 then         'if swset2 is 1
    high led2                'then turn on RB5 (and hence the LED)
    low led2                 'else, LED is off
    If swset1=1 and swset2=1 then
    toggle swset5
    if swset5=1 and sw1=0 then
    low led1
    low led2
    high led1
    high led2
    I have even tried removing the "else" part at the end of the code so it reads
    toggle swset5
    low led1
    low led2
    But that still fails to work correctly.
    Any advice guys and gals ??
    Wink Wrong scenario ...
    Hi, Malc
    as SWset5 is tested AFTER the swset1 ... your condition never can happend, or during so little time, it can't work properly.
    malc-c's Avatar
    malc-c Guest
    So are you saying its the logic of PBP or my program logic that's not right
    I modified the code to add in a new var for LED3 to test for the condition "swset1=1 and swset2=1 then swset5=1 and it didn't work either
    swset5=1
    swset5=0
    if swset5=1 then
    high led3
    When swset1=1 and LED1 is lit, and swset2=1 and LED2 is lit, LED3 fails to light, ergo swset5 can't =1
    So any ideas on how to do what I want it to do ??
    Talking PbP is right
    YOUR Logic is wrong ...
    malc-c's Avatar
    malc-c Guest
    You ain't going to make this easy for me are you !
    A hint in the right direction would help !!
    malc-c's Avatar
    malc-c Guest
    OK following your advice I RTFM and it states
    If (B0 = 10) And (B1 = 20) Then loop
    So I applied the same logic to the code
    If swset1=1 and swset2=1 then occ
    occ:
    high led3
    ie if swset1 and swset2 both =1 then jump to occ, occ simply turns on LED3
    This didn't work. It seems that its ignoring the "and" part of the statement
    I mean this ain't exactly rocket (or should I say space shuttle ) science
    Dec 2005
    Perhaps because you ignored the parentheses?
    Wink the last ...
    Hi, Malc
    try this:
    CMCON=7
    Swset1 var bit
    Swset2 var bit
    Swset5 var bit
    low led1
    low led2
    Swset1=0
    Swset2=0
    if SW1=0 then
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    loop: IF sw1=0 then loop 'wait for button release ... Yessss !!!
    GOTO jump
    Jump:
    toggle swset5
    Goto Main
    And now try to understand WHY !!!
    How dare you post our private stuff in public
    LOL! yeah maybe you're right... but damn you should be really strong to break my arms, legs and spinal cord. Guys, be aware of that!
    LOL Melanie, at least i wish it could be true
    Ok let's stop it here.. there's somebody who need help here, but Alain give some great tips.
    Talking One little last ...for the trip.
    Ok let's stop it here ...
    Thanks to Luciano, ve've a good idea of uptown girls at night ...
    cool, Malc ... cool !!!
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Acetronics
    Hi, Malc
    try this:
    Thanks, and yes it compiles OK and in tests works as required approx 70% (ie 7 out of 10) of the time. On three attepts LED2 remained lit, but its a lot better than my 0% success rate
    OK I'll have a go...
    CMCON=7
    Swset1 var bit
    Swset2 var bit
    Swset5 var bit
    low led1
    low led2
    Swset1=0
    Swset2=0
    Sets up the PIC and the varibles
    if SW1=0 then
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    If pin is grounded then check to see if varible bit swset5 is set high, and if so then swset 1,2 and 3 are all set low
    constantly loop round checking pin sw1 to see if grounded
    GOTO jump
    and if so, goto the section of the code labled jump....
    Jump:
    if the varibles swset 1 is high then turn on its corresponding LED, if low then turn off the LED, same thing for swset2
    toggle swset5
    Goto Main
    If swset1 and swset2 are both high then change the state of swset5 to high, which iwhen checked by the line above
    IF swset5 =1 THEN
    swset1 = 0
    swset2 = 0
    swset5 = 0
    resets swset1, swset2 and swset5 back to 0, and conversly all LEDs are turned off
    Checks sw2 and changes the state of swset2 (and thus LED2)
    Well how did I do ??
    malc-c's Avatar
    malc-c Guest
    Guys you crack me up... here am I trying to get technical and you guys are trying to put me mind off the subject by posting pictures of pussy on a public forum
    i hope you remember that you miss one word !
    The Melanie bad hair day is back!
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=445&d=1125012225">
    While we're at that... http://www.picbasic.co.uk/forum/showthread.php?t=2050
    malc-c's Avatar
    malc-c Guest
    That's a shame, either its my browser or the plug in, but I only get audio when viewing that clip
    With regards to the topic of this thread (Mel, I am trying to keep this on topic !) I hooked up a test track and placed a magnet on a loco to see how it worked, as I had been using magnets passing over the switches by hand to test the code.
    I don't know if it's due to the speed of the train (slower than my hand tests) but I got a 1 in 10 success rate of both LEDs being turned off when the train exited the siding
    The other question I have, is as I need 8 inputs and 8 outputs, can I use port A in the same way as port B. The thing that concerns me is the MCLR pin... do I have to do something to configure this as a normal input as I've read that this can cause problems if not treated right ??
    Cheers
    Malcolm
    (rapidly aging and going bald by pulling my hair out over this "issue")
    Wink Time to grow ...
    Hi, Malc
    Don't you think it would be the time to test the "BUTTON" statement, instead of " if SW1=0 then ..." ???
    May be we could also try more sophisticated debouncing ... but one thing after one !!!
    you want to play the " Speedy Gonzalez " ... no problem this side !!!
    PS: Try this : http://www.darreltaylor.com/files/ouchywhip.wav ...
    malc-c's Avatar
    malc-c Guest
    Yeah, I think I might have a go at the BUTTON statement...
    Let me go away and RTFM first, have a play, try and get something together before bailing be out
    Before I start though, any comments on configuring PORTA (inc MCLR) for in/outputs ??
    Malc
    Wink Enlightments ???? Ok ...
    Here a cutout ...
    PORTA = 0 ' declare port level BEFORE port direction = safe power-on
    PORTB = 0
    'Pour 16F628
    CMCON = 7 ' PortA Digital inputs
    CCP1CON = 0 ' PWM off
    ' DATA @1,word 625,0,word 545,word 750 ' pre-setting EEPROM
    ' Initialisation commutation : Vérification batterie
    init:
    battok = 1 ' setting critical variables ...
    dejavu = 0
    bougie = 0
    error = 0
    Servo = 0
    TRISA = %00000011 ' Port Direction
    TRISB = %00000001
    Pause 400 ' Stabilisation au branchement
    GoSub verbatt ' beginning of real program ...batt testing i.e.
    Cheers
    malc-c's Avatar
    malc-c Guest
    Default Don't you just love the manual.
    Ok, trying to get my head round the BUTTON statement, and failing.. bu I just love the line
    In general, it is easier to simply read the state of the pin in an IF..THEN
    than to use the BUTTON command as follows:
    If PORTB.2 = 1 Then notpressed
    which was what I was originally doing .....
    Oh well ... I'll keep trying
    malc-c's Avatar
    malc-c Guest
    Default It works !
    Ok after a lot of tries I finally have something that works. Here's the centre section of the code with the initialisation parts ommited for clarity
    LED1 var  PORTB.4       'LED1 (green) on pin 10 (RB4)
    LED2 var  PORTB.5       'LED1 (red) on pin 11 (RB5)
    SW0 var PORTB.0          'switch input pin 6 (RB0)
    SW1 var PORTB.1          'switch input pin 7 (RB1)
    SWFLAG1 var Byte      ' counter for track 1
    Swset1 var bit
    Swset2 var bit
    low led1
    low led2
    Swset1=0
    Swset2=0
    SWFLAG1=0
    if SWFLAG1 >2 then     ' if the counter is >2 then reset all
        swset1=0
        swset2=0
        SWFLAG1=0
    If SW0=0 Then
    swflag1 = swflag1 +1  ' increase count by 1
    swset1=1
    If SW1=0 Then
    swflag1 = swflag1 +1  'increase count by 1
    swset2=1
    if swset1=1 then
    If Swset2=1 then
    Basically rather than try and compare a condition of swset1 and swset2 and SW0, I simply used SWFLAG1 as a counter to count the number of times the switches are activated, and if it is greater than 2 reset the couter and swset 1 and 2 to 0.
    Now when sw0 goes low for the first time SWFLAG1 is = 1, when sw1 goes low SWFLAG1 =2 then when the loco is placed at the front of the train andis driven over SW0 for the second time SWFLAG1 =3. As the "IF SWFLAG1 > 2" condition is reached, SWFLAG1 is reset to 0, as is swset1 and swset2.
    Now just have to replicate this for the other 6 inputs and outputs
    I know this may seem trivial to the more experienced programmers, but its my first real program with PBP that is beyond the simple flash a LED, and I'm really pleased that I managed to figure something out, after some guidance from you guys here.
    Malcolm
    Oh, and seeing that I RTFM and did my homework... do I qualify for a dozen lashes form Mel (alias Ms Whippy )
    Wink BUTTON .... why ???
    Hi,Malc
    The IF THEN Statement implies your switch is an ideal switch and debouncing not tricky ...
    BUTTON is more complicated and slow ... but works in very difficult situations.
    The state of art is to verify the button has not changed its state BEFORE debouncing time has ended ...
    Multiple IF ... THEN ... ELSE following each others reach that GOAL ...
    There is another way of thinking here Alain...
    Once a switch has closed (as detected by the first IF/THEN) then the assumption is that whatever event caused it to close (or open) is not a False Alarm and the event intended to happen (eg a User pressing a button). You therefore need no futher IF/THEN's to see if the contacts are still closed after the debounce time period expries.
    All you have to do is delay looking at that switch again for a period of time greater than any possible contact bounce to ensure you don't register that event a second time (as would happen if you used interrupts for example).
    Now the delay time is really down to the application. I tend to use 100mS for Keyboard Buttons, because that gives an 'auto-repeat' of 10cps which is quite nice when viewed on a display. Naturally, if you're timing something that happens a lot quicker, then you need to reduce the bounce delay time, but if you get it too short, you'll run into the multiple contact closure problem.
    It's difficult to guage and is done mainly by look/see and a bit of experience because different switches (be they contacts on a Switch, Relay or a Reed) all exhibit different closure properties and have different bounce periods. Best method I've found is to overkill the delay as much as possible.
    The best method for registering an event, but discarding any False Alarms, is to see how long a switch remains closed over a period of time. That then will require multiple IF/THEN's both at the beginning and at the end of the debounce period.
    malc-c's Avatar
    malc-c Guest
    Melanie, you are spot on.. The issue I have here is that each time the reed is triggered it will never be the same time period as the last, as some trains will pull in to the siding slower than others. I've found that, although not probably the ideal way, having lots of IF/THEN sections for checking the switches and activation the LEDs works, and more to the point I understand what happening and how I debugged the code to get it working.
    The only issue I've run into with the 628 is replicating the action on PORTA. As taking MCLR low seems to reset the PIC even when including Alain's suggestions
    PORTB = 0
    'Pour 16F628
    Its not much of a problem as I have another 628 PIC so I could use 2 PICs to cover the four sidings, but it would seem such a waste just using half of two chips. Looking at the datasheet all inputs on PORTA are ST where as PORTB has ST and TTL, could this be part of the problem in getting PORTA to work in the same way. Is there any command to turn off the VRCON or Vref function, so that PORTA is strictly in/out and all multiplexed pin options are turned off?
    malc-c's Avatar
    malc-c Guest
    OK I give up,
    Does anyone know of a PIC with 28 pins, internal OSC (or runs off a 4Mhz xtal if no 28pin pics have internal OSC option) that has standard TTL ports...
    Having MCLR on an input which is grounded has resulted in so much distress in the household I'm almost considering using descrete logic chips to do the same function.
    Cool Take care !!!
    Hi,Malc
    The 16F876A or 877A ( 40 pins ) are the ones ( huge memory, no internal bugs ...etc ...)
    BUT, as they can do lots more they do need lots more understanding of their different options ...
    Why don't you try to have a good working simple circuit before building the Babel tower ... you're on the soapy side ... still time to become humble.
    You have of course set the Config Fuses to have MCLR as an Input Pin?
    I use MCLR as an I/O in dozens of 16F628 designs without problems, so I suspect you haven't.
    Wink Mel ... you're an angel ...
    Our friend MUST discover some little things by experience ...
    Copy and paste is really the worst solution !!!
    He surely forgot that !!!
    Apr 2006
    New Hampshire USA
    Default I wonder.....
    I am new to the forum and hope not out of line...
    Clues:
    Quote Originally Posted by Malcolm
    "The LED brightens" (unintentionally) does not sound very digital.
    I wonder if there might be an interaction between the magnetics of the locomotive "engine" and the reed switch. Possible even modulating the switch as the loaded motor slowly passes over the switch. Monster size "contact bounce". Or perhaps the magnetics of the motor offsets the permanent magnet, causing it to not always trigger the reed switch.
    If this is part of the problem then Melanie's suggestion would certainly apply:
    Don't forget the sequence of permanent magnet and motor chatter would depend upon the direction of travel (just to make it interesting).
    This may not be any part of Malcolm's problem but something we should keep in mind when using reed switches or hall effect devices. Don't ask why I thought of it.
    This forum is the most useful resource, for beginners, on the entire web. Thanks to all you PIC gurus, most of the "gotchas" with PICs, can be found with a forum search. Thanks for all your hard work.
    -Adam-
    Wink Good discussion ...
    Hi, Mel,
    Here, the problem is we do not know for how long the magnet will be close to the reed switch ...
    so, how to fix a reliable debouncing time ... ???
    But we know one thing : if the reed switch is triggered, say 20 or 50ms long ( real debouncing ) ... the magnet is really here !!!
    So, let's consider the triggering is then real.
    We do not want new triggerings before some times ( That's THE problem ), even the magnet is still here ... right ???.
    Let's say we allow few seconds for the magnet to go further ... before testing it once more.
    If tested close ... the train is still here, stopped or so : What to do ????
    If tested Open ... let's go on our program.
    Back to PicBasic programming, we see here that it's the original scenario which is wrong, cause it doesn't allow a correct work of the Hardware connected.
    In primary schools, our teachers always repeated us a clearly written problem has already found half its solution ...
    malc-c's Avatar
    malc-c Guest
    When programing (using WinPIC pro) I've tried setting MCLR input enabled (and disabled) and it didn't have any effect. It seems that the problem is with the config as you suggest, however as I'm a newbee it would be nice if you could tell me how to set MCLR as I/O (well I guess input only).
    Anyway, I've had a think and came up with the idea of connecting the two reed switches for each track to the same pin and simply counting the times the pin is grounded, and then using the IF/THEN statement to set the condition of the two LEDs. This works for a while and then the PIC seems to stop running
    Here's the revised code:
    PORTB = 0
    VRCON = 0        ' Voltage reference disabled
    OPTION_REG.7 =    0
    TRISA=%00000000        'set PORTA as all output
    TRISB=%00001111        'set RB4,5,6 &7 as output and the rest input
    'DATA @1,word 625,0,word 545,word 750 ' pre-setting EEPROM
    @RC_OSC_NOCLKOUT
    @WDT_ON
    @PWRT_ON
    @MCLR_OFF
    @BOD_ON
    @LVP_OFF
    @CPD_OFF
    @PROTECT_OFF
    ' set up outputs to drive LEDs
    LED1 var  PORTA.1
    LED2 var  PORTA.0
    LED3 var  PORTA.7
    LED4 var  PORTA.6
    LED5 var  PORTB.7
    LED6 var  PORTB.6
    LED7 var  PORTB.5
    LED8 var  PORTB.4
    ; set up reed switch inputs
    SW0 var PORTB.0
    SW1 var PORTB.1
    SW2 var PORTB.2
    SW3 var PORTB.3
    ; set up switch counters
    SWFLAG1 var Byte
    SWFLAG2 var Byte
    SWFLAG3 var Byte
    SWFLAG4 var Byte
    'set all LEDs to off
    low led1
    low led2
    low led3
    low led4
    low led5
    low led6
    low led7
    low led8
    'zero the switch counters
    SWFLAG1=0
    SWFLAG2=0
    SWFLAG3=0
    SWFLAG4=0
    ' check counters and reset if >2
    if SWFLAG1 >2 then
        low led1
        low led2
        SWFLAG1=0
    if SWFLAG2 >2 then
        low led3
        low led4
        SWFLAG2=0
    if SWFLAG3 >2 then
        low led5
        low led6
        SWFLAG1=0
    if SWFLAG4 >2 then
        low led7
        low led8
        SWFLAG2=0
    'siding one operation
    If SW0=0 Then
    if swflag1=1 then
    high led1
    If SWFLAG1=2 then
    high led2
    'siding two operation
    If SW1=0 Then
    swflag2 = swflag2 +1
    if swflag2=1 then
    high led3
    If Swflag2=2 then
    high led4
    'siding three opertaion
    If SW2=0 Then
    swflag3 = swflag3 +1
    if SWFLAG3=1 then
    high led5
    If SWFLAG3=2 then
    high led6
    'siding four operation
    If SW3=0 Then
    swflag4 = swflag4 +1
    if SWFLAG4=1 then
    high led7
    If SWFLAG4=2 then
    high led8
    Goto Main
    When first powered up I can get it working fine, led1 lights the first time sw0 is triggered, then led2 the second time, and then both go out on the third pass of the magnets. This works for all four reed switches, for about 60 seconds and then seems to lock up in what ever state the LEDs are set at. I have 10K pull ups on all input pins, and a 10K pull up on MCLR
    Any further comments ?
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Addressing with Dip Switch or ???
    By tazntex in forum mel PIC BASIC Pro
    Last Post: - 16th September 2008, 12:19
  3. 16f628a wont wake up
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2008, 14:22
  4. SLEEP mode 16F628A
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 25th April 2006, 17:26
  5. 16F628A using PORTA.4, and it works, but...
    By zx81 in forum mel PIC BASIC Pro
    Last Post: - 17th August 2005, 08:45
