Serin
Results 1 to 5 of 5
Thread: Serin
    france
    Default Serin
    Hello
    I want that the program has patience 20 seconds, if no data received, then it will write the data,
    Star: HIGH PORTB.7
    HIGH PORTA.3 'activation
    SERIN PORTA.2, T9600,20000, safe1, [“SYN”], code [0]
    GOTO safe
    safe1: code [0] = 12
    code [1] = 12
    safe: LOW PORTA.3
    FOR I = 0 TO 1
    LOOKUP2 codes [I], [48,49,50,51,52,53,54,55,56,57,42,35,45], datatx
    code [I] = datatx
    next I
    Thank you
    I think you should set/reset somewhere the code [0] and code [1] to other value, say 0. After a failure on Serin they will always hold 12.
    france
    Default timeour
    Hello
    I modified this manner, and times it jump and of the times not
    Timeout con 20000
    star: serin PORTA.2, T9600, timeout, save1, [“SYN”], code [0], code [1]
    TOGGLE 7
    GOTO save
    Thank you
    PIC# ?
    Schematic ?
  1. Serin EEPROM Programmer
    By dirtbiker5627 in forum mel PIC BASIC Pro
    Last Post: - 25th February 2010, 00:48
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  4. Serin with low voltage
    By f_lez in forum General
    Last Post: - 21st August 2006, 12:52
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
